#41 | |
#42 | |
#43 | |
Perhaps you could start a thread showing the Lineup Quattro Output Stage and ask for comments. Looks like there would be no need for a VAS with this Output Stage.
KL. |
#44 |
Perhaps.
But on the other hand, I have seen 1000-s of postings being much more offtopic. More than posting my 4-stage emitter follower here. Sometimes is even hard to know you have came right, when clicking one topic and you end up in some strange discussion about whatever else. As I see it, when somebody search for 'tripple emitter follower' it wont hurt they can look at some alternatives, that are close to same idea & function. Regards
lineup |
#45 |
Hi Lineup, nothing to do with on or off topic ...
For me, I think that it is a very interesting circuit. Definitely worth discussing ... anyhows, that's upto you.
KL. |
#46 |
Happy New Year everybody
KL. |
#47 |
With mosfets you dont need a triple EF drive, the gates can be driven directly by VAS if you like, as the loading of the power fets does not traverse down the gate like it does on current driven devices like BJTs. Mosfets are voltage driven. However for multiple power fets in parallel, you may still want a driver stage to aid higher frequencies though, as the gate capacitance of each of the fets add up and eventually loads VAS enough at higher frequencies that frequency response goes down and distortion goes up. But there is no need for a triple EF on a mosfet output, only for higher power output BJT amps working into lower load impedances. >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >>>>>>>> so can we drive the 2 ohm load having 5 pairs of IRFP240 and IRFP9240? continuously? |
#48 |
how many pairs of required to drive the 2 ohm load?
#49 |
I want to drive a 4 ohm woofer so would like to bridge the amp hence need amp stable in 2 ohm... thought of triple EF but like said on the above post its said that its not required to have triple EF so can It drive 2 ohm load? how many pairs are required to run the IRFP240 to make a stable and safe amp...
| Triple Emitter-Follower as OPS for the Aikido | teodorom | Solid State | 7 | 5th June 2007 09:55 PM |
| Question about direct coupling a anode follower into a cathode follower. | G | Tubes / Valves | 45 | 29th July 2004 06:47 PM |
| Switches - Dual Triple Pole, Triple Throw | jackinnj | Swap Meet | 0 | 27th January 2003 07:18 PM |
