I'm building Anthonys sym-amp but after reading a thread about different method of mechanical design(dont remember wich..) I want to change....
Is there any problem to mount all IRFP240 on one copper plate and all IRFP9240 on another, so that they are electricly connected on each plate, and then isolate the two plates and mount them to the heatsink? Im hopin this will better the thermal resistance. I really dont see any problems with this, or is there (oscillating??)? What do you think? Thanx! Richard |
#2 |
Warp Engineer
On Holiday
That should be ok but I wouldnt count on getting lower Rth because you've then got an extra thermal joint.
#3 |
Electrons are yellow and more is better!
Richard, I guess your cooling is not a big problem. Adding copper won't add much besides the coolness factor. It's nothing wrong with mounting transistors on isolated heatsinks but the basic rule is to keep it compact. I would recommend to have grounded heatsinks and isolated MOSFET's.
As Audiofreak says, try to have as few thermal junctions as possible. The best thing is actually to mount the transistors directly on the heatsink (if it's possible).
/Per-Anders (my first name) or P-A as my friends call me |
#4 | |
Av800 I want to prototype. Gonna use 3/16" thick copper plate and mount each mosfet to the copper with no insulation, just white goo. Then isolate the copper plate (mica?) to the aluminum heatsink. If you search the archives, there is a good thread about this. 1/2 the people seemed to like the idea, the other 1/2 didn't. heheh In my case, my copper plate is 3/16" thick x 1.5" width and the length is about 10".. The heatsink plate is 1/4" thick aluminum. Doesn't hurt to experiment. Also, I wonder if the copper plate will be a good +V and -V for the transistors since the tab = drain if I'm not mistaken? I might try this stuff instead of generic white thermal compound.. http://www.arcticsilver.com/as3.htm Anyone use this before ? |
#5 |
i've used it on my CPUs HSF. if you want info on it you may wanna go to any computer hardware forum, overclockers are always trying to get the extra degree of cooling.
as i recall, hardocp.com did a review: http://www.hardocp.com/article.html?art=MTQ0 however it only goes up to AS2, not AS3.
if only it could be used for good, not evil... |
#6 |
I have done this twice and my experience is - too get good results the copper and heatsink surfaces really have to be FLAT. The extruded aluminium heatsink I used had a bit of a bow in it; no big deal for small contact areas but when you span a much greater width with your copper plate there is a far greater chance of only marginal contact.
There are much better heat conducting materials than mica available nowadays from the likes of Bergquist, Chomerics and the like. The tradeoff in different grades of materials offered is voltage rating vs thermal resistance. You don't need much of a voltage rating so this should work out well.
Best-ever T/S parameter spreadsheet. http://www.diyaudio.com/forums/multi...tml#post353269 |
#7 |
just a tip i tryed arcticsilver on eletronics if your heat zinc is grounded it will short......
conducts electricity..... allso shorts out athlon's ![]() |
#8 |
hmm, that's odd. my athlon is very much fine with the AS3. i need to put the kt266/333 cooling mod back on. i had cpu temps 2 degrees BELOW ambient at idle! full load was the same. i've used AS3 for a TBird and a Palimino and had no ill effects.
#9 |
ya works good on athlon's if thin my customers put it on thick
doo a fet hmm u take your chances |
#10 |
peter may be still selling these thay work great and you dont need to make the fet super tight for it to work good..hmm the name i think was ceramic oxide. no goo needed
| Isolating a hum? | Bogie | Solid State | 10 | 26th January 2005 01:14 PM |
| What to use for TO-220 isolating pad? | leadbelly | Chip Amps | 18 | 15th July 2003 04:57 AM |
| Page generated in 0.13687 seconds (72.14% PHP - 27.86% MySQL) with 11 queries |
