current spike question
Old 13th December 2008, 08:50 PM   #1
foobar is offline foobar  United States
Default current spike question
I'm trying to design my first amplifier. I've been simulating my design with pspice, and the current signal that feeds from the input diff amp stage to the voltage amp stage has spikes and ringing at it's peaks. I'm wondering what could be causing these large spikes? Please see the attached image. Would these be considered parasitic oscillations in the current signal?
Thanks.
Old 13th December 2008, 09:32 PM   #2
darkfenriz is offline darkfenriz  Poland
darkfenriz's Avatar
I guess it is correction for crossover distortion, which is normal.
Crossover distortion happens at zero crossing of the sine, but diff pair's output and output signal are phase shifted by 90 degs, because voltage stage is integrating.
Adam
Old 14th December 2008, 07:49 PM   #3
Thanks, that was it. It wasn't readily apparent from the plot of the output voltage, but I adjusted the output stage bias and that cleared up the current signal.
current spike questionHide this!Advertise here!
OPT Voltage spike protection with zeners bigwill Tubes / Valves 8 17th July 2009 04:24 AM
spike from SG3525 jegandren Power Supplies 7 13th September 2008 03:23 PM
no spike protection allowed tryonziess Chip Amps 6 13th May 2007 05:52 PM
Speaker Spike bjackson Multi-Way 8 9th May 2005 01:12 AM
Anyone use these Spike Feet? m1abrams Multi-Way 2 22nd July 2004 06:54 PM
