Reamed after a prolific inventor by the name of George C. Sziklai.
In essence, a high gain super transistor, somewhat similar to a CFP. But there are major difference feature is a coherent local feedback. Why is the coherent local feedback? Basically, more difficult to design local feedback is the bias circuit That circut generate a difference between two rails, then a distortion. Using two diode for fixed bias of drivers: signal in just one, NFB just one, so coherent. Thermal drift is compensate by two NTC resistors on each final transistor's case. It is easy to break out into high frequency oscillations with two capacitors or a little coil between drivers and finals BJT. Performance like a live concert without distortion.
visit my best audio idea http://www.esafono.it/DACTONE.htm |
#2 |
You should go into marketing.
#3 |
same concept
but with a partitor between NFB so a voltage gain for example 5R6 and 24R in output stage
| Looking for complementary NPN-PNP pair | boB_K7IQ | Solid State | 1 | 16th November 2008 05:30 AM |
| On/off bump in complementary pair amp | scottw | Solid State | 22 | 27th July 2006 03:47 AM |
| JFET complementary pair | Leolabs | Solid State | 18 | 7th January 2006 06:27 AM |
| How important is complementary transistor pair matching in class B amp? | caesar148 | Solid State | 10 | 15th October 2004 07:06 PM |
| Which 4th order XOs are phase coherent? Are SWs of value? | rick57 | Multi-Way | 0 | 14th April 2003 03:40 AM |
| Page generated in 0.08164 seconds (76.16% PHP - 23.84% MySQL) with 11 queries |
