Abomination! or Painting a Mustache on the Mona Lisa meets the Island of Dr. Moreau
Old 14th April 2009, 01:20 AM   #211
homemodder is offline homemodder  Portugal
Just found my handdrawn schematic of the inputstage, I wrote down the model, its the L550, I ll try find full schematics on the net.
Old 14th April 2009, 02:30 AM   #212
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Originally posted by homemodder
its the L550,
Thanks homemodder,
I found it but it the whole amp schematic. Some ideas for me here.
I cut this part out:
Old 14th April 2009, 07:28 AM   #213
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
If only you had the schematics of the 550-II series.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 14th April 2009, 08:02 AM   #214
Jacco, that amp looks good, what is it about the 550 II series, what changes were made ?? I like these Luxman amps, they are very well designed, never listened to one but there are many people critisizing them and I find this unbelieveable. I have just finished prototyping and modifying a design based on a elite series Pioneer from 1988, another hell of a good amp, with just 24 transistors I easily get full power THD20 figures of quite a bit less than 0.001 200w and here we are 20 years later coming up with incredible complex designs to achieve the same. To me it sounds excellent, every bit as good as electrocompaniet. I dont understand the reason these japanese amps are said to sound bad, only if its a parts thing and then we are not talking of the transistors used. Ive come to highly respect some of these japanese designs.
MJL21193, yep thats the one. Ill make a clone of it on ltspice and see what it can do.
Old 17th April 2009, 10:28 PM   #215
MJL21193's Avatar
I continue to play...
Old 17th April 2009, 11:46 PM   #216
Lumba Ogir is offline Lumba Ogir  Sweden
Banned
John,
R2 and R32 could be shifted to active sources.
Old 18th April 2009, 12:52 AM   #217
MJL21193's Avatar
Hi Lumba,
Not sure what you mean - R2 limits current from VAS bases to D2, D3. R32 is a output emitter resistor - you must have meant R39 which likewise limits current.
New schematic (again). Looking better?
Old 18th April 2009, 02:09 AM   #218
MJL21193's Avatar
And again. Change in the compensation scheme:
Old 18th April 2009, 02:12 AM   #219
Banned
John,
maybe we can clear this up. Firstly, R2 is a current source (should have high impedance, positioned on the collector side), providing current for D1 and D6, which form a voltage reference (should have low impedance, positioned on the emitter side). An active current source has much higher dynamic impedance than a resistor.
D2 and D3 are not needed.
Old 18th April 2009, 02:40 AM   #220
MJL21193's Avatar
Thanks Lumba,
I can be thick-headed
Like this? Also, I ditched the other compensation scheme.
Abomination! or Painting a Mustache on the Mona Lisa meets the Island of Dr. MoreauHide this!Advertise here!
Old meets new but can this be solved? barchetta Pass Labs 4 11th March 2007 07:29 PM
Old Meets New philipbarrett Tubes / Valves 3 22nd August 2005 12:03 AM
