Abomination! or Painting a Mustache on the Mona Lisa meets the Island of Dr. Moreau
Old 31st December 2008, 07:32 PM   #191
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Default Re: re post 182
Originally posted by ostripper
.. it is your widlar CM that will increase OLG...
Hi OS,
Look again, that isn't a CM. It's 2 CCS only different from the Abomination in that it uses a T instead of an LED for bias.
Originally posted by atiq19
some real amp testing can bring more practical results.
Hi atiq19,
Good tip for the simulator.
Such compensation is easy to tack on after the board is done if I find that it is needed.
If this is anything like the Abomination, it won't be needed - I have tested that amp already with capacitive loads.
Fixed up the schematic:
Old 31st December 2008, 07:52 PM   #192
MJL21193's Avatar
Originally posted by KLe
Nice John ... as you would say, keep it simple
Hi KL,
Me being a minimalist again
This only uses two more transistors (total=28).
The question is, is it a better amp? I have massively improved PSR, but below a certain value, this won't be a discernible improvement (IMO).
I have about the same 1k THD. Spectrum of the harmonics I don't trust, but both amps simmed show 2nd stronger than 3rd, with not much up higher. I haven't tested 20k yet.
Loop gain:
Picture perfect.
Old 1st January 2009, 02:52 AM   #193
ostripper is offline ostripper  United States
ostripper's Avatar
As I said , it's the cascoded VAS that makes the grade..
I had the exact same plot at 1.1mhz UGwith 47pf Cdom/same VAS..
(63 db at 100hz /-100 phase- UG intersection)
[that is with 68pf]
Much better than "standard" blameless or even symasym
topology(simulation). The question remains, How will a cascoded VAS sound ,(maybe you could tell me as you have heard it..)
The french article earlier in my post and the "magic resistor"
definitely changes the distortion content (stupid low already)
increasing H2. you might want to include pads for the resistor
in case my hunch is right.
Os
Old 1st January 2009, 12:42 PM   #194
MJL21193's Avatar
Feeling a wee bit queasy this morn'...
That's a dead ringer for this amp! There is magic in these designs, for sure.
As for the sound, well I listened to the Abomination and it sounds very good, very smooth in the mid/high. There seemed to be a slight difference to my Patchwork, but that may have been imagined.
Personally I don't think there would be an audible difference as long as it it working as it should.
Old 13th January 2009, 08:27 PM   #195
KLe is offline KLe  Australia
Banned
Hey John
Any more Bain/Abomination changes
Old 14th January 2009, 02:29 AM   #196
MJL21193's Avatar
Hi KL,
Bain is on the shelf until I get the time and motivation to attack it again. I am encouraged by the recent progress though and think it can be a worthwhile amp to develop.
I'm busy with projects I started and didn't finish - one of which is a phono preamp. I've made several board changes and etched several boards in an attempt to find the most quite one.
Also started and halfway finished a pair of small speakers for my office that will play my new K10A. These have a solid wood baffle with a waveguide carved in for the tweeters. Here's how they look. A bit rough still in this pic, but they have been sanded and look a lot better now:
I'm a sucker for punishment.
Old 11th April 2009, 02:21 PM   #197
Lumba Ogir is offline Lumba Ogir  Sweden
Banned
MJL21193,
correct application-without explanation.
Old 11th April 2009, 08:33 PM   #198
MJL21193's Avatar
Originally posted by Lumba Ogir
MJL21193,
It's not clear to me how this is an improvement. Your change lowers the current through U21, U22. Too low and reducing R7, R8 will not be enough. I end up with insufficient current through the VAS.
Old 11th April 2009, 11:54 PM   #199
Banned
MJL21193,
it is the configuration of principle, please choose your operating points.
Old 12th April 2009, 03:46 AM   #200
MJL21193's Avatar
Lumba,
I'll work on it.
Abomination! or Painting a Mustache on the Mona Lisa meets the Island of Dr. MoreauHide this!Advertise here!
Old meets new but can this be solved? barchetta Pass Labs 4 11th March 2007 07:29 PM
Old Meets New philipbarrett Tubes / Valves 3 22nd August 2005 12:03 AM
