Abomination! or Painting a Mustache on the Mona Lisa meets the Island of Dr. Moreau
Old 31st December 2008, 12:41 PM   #181
R.I.P.
no emitter load on the U1&5 drivers.
regards Andrew T.
Old 31st December 2008, 12:48 PM   #182
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Default Re: Re post 174
Originally posted by atiq19
any reason for not using thermal trak? tripple emitter follower instead of CFP?
I have another end use for this amp and it's better (for me) if it uses regular devices. The triple EF shows slightly better THD performance (here) and is more stable. Also, to change it up
how about bob cordell thermal-trak bias spreader and T-output? u need to modify the upper and lower CCS for VAS connection.
you could add mosfet flavour by swapping bjt driver over with low Ciss MOSFET.
The bias solution I used in the Abomination works splendidly, so I can't see a reason to change it, but thanks for pointing out the circuit - I may use it someday.
I'm not ready for FETs yet. Maybe sometime in the future...
Despite the fact that the amp is absolutely stable in simulator, I would still like to have a small phase lead compensation cap (1-3pf) from collector of VAS to fb loop.....
I haven't looked at the gain and such in this one, but the Abomination didn't need any such compensation.
Old 31st December 2008, 12:49 PM   #183
ostripper is offline ostripper  United States
ostripper's Avatar
The CFP input was in the last version of this, several posts ago. I haven't examined the gain yet
I did CFP's and noticed very little improvement.. it is your
widlar CM that will increase OLG... Strange, when I did your
amp thats what I did as well as use the zetex killer Hfe
trannies to get 70+ out of it (abomination)
It looks like your amp is a hybrid of FA2 and 3 (cascode)
Still you have a "lavardin amp" as well as me...
Read this ....http://peufeu.free.fr/audio/memory/memory-5-vas.html
All about cascoded VAS's (fast, fast)
OS
Old 31st December 2008, 12:50 PM   #184
ostripper's Avatar
With a triple you might have to..
Os
Old 31st December 2008, 12:51 PM   #185
MJL21193's Avatar
HNY Andrew,
This darlington configuration will not work? I wanted to play with an R between, E to B.
Old 31st December 2008, 01:01 PM   #186
atiq19 is online now atiq19  United Kingdom
Default re post 182
you can check necessity of such compensation on your simulator by parallelling a ,say, 2.2uf capacitor at the output..
however, a single parallel cap does not necessarily represent a real life complex x-over network loudpeakers variable impedance.
some real amp testing can bring more practical results.
Old 31st December 2008, 01:24 PM   #187
Default some tuby fun with abomination
in the spirit of 2009,
how about changing fb loop with some twist of 6GM8 (low voltage ) triode...
in this way the amp could be switched from pp to se.....2nd harmonic dominant..
since 6gm8 is low voltage, you don't think about HV.. you may have to shield 6GM8 on actual pcb..
cheers
Old 31st December 2008, 01:26 PM   #188
Default more tuby fun
the previous one curtesy JRB
this one Smoking Amp,
Old 31st December 2008, 01:27 PM   #189
Default oops
my mistake..
Old 31st December 2008, 05:08 PM   #190
KLe is offline KLe  Australia
Banned
Nice John ... as you would say, keep it simple
HNY
Abomination! or Painting a Mustache on the Mona Lisa meets the Island of Dr. MoreauHide this!Advertise here!
Old meets new but can this be solved? barchetta Pass Labs 4 11th March 2007 07:29 PM
Old Meets New philipbarrett Tubes / Valves 3 22nd August 2005 12:03 AM
