#121 | |
That sounds like a worthwhile thing to do. Here's how the sim shows it with a "real" power supply. Notice the magnitude of the ripple on the output as opposed to that from the supply. |
#122 | |
Well of course the PSRR is high at such a low frequency, genius. |
#123 | |
Only my close friends are alllowed to call me by my first name... |
#124 | |
Lets see... that both rails together or one at a time? Let's try one - 72.6VDC rails into 8 ohm load ....equals ~9 amps...or 654 watts...getting quite warm here! Oh, the 4 ohm, I forgot. that's only 1318 watts into my trusty dummy load. No problem.
#125 | |
#126 | |
Ok, now I get it. Yes, I feel embarrassed - slightly. I'll recover . I did as wg-ski instructed: I connected another amp to the same supply (OS' Frugal2) and drove it with my signal generator. It was connected to the 8 ohm dummy load. I drove this amp to clipping at different frequencies. The amp being tested (Abomination) was connected to the scope and a fullrange 8 ohm speaker. Even though the scope did show some ripple, especially at higher frequencies, there wasn't enough to be audible through that speaker. Not depending on my hearing, I asked my 18 year old son to have a listen - nothing. To be sure I switched to a square wave and then and only then could he hear a very faint buzz from the speaker. Oh well, it must be below the noise floor, and apparently I have a good design AND layout. |
#127 |
AND a thick head.
Looks like Sponge Bob has killed another thread. |
#128 | |
It's helpful responses like this and from that social dilettante Glen that make this so much fun. Keep up the good, encouraging work fellas. |
#129 | |||
You don't think that it is worth Simming?
KL. |
#130 | |
Hi KLe, The sim may show some DC on the output (it does: -3.5V) but that can't be relied on. Real measurements are needed and to justify extra DC offset, it would need to "sound" better, so some critical listening would be in order. Not my ears though - I strained them listening for sound of bad PSRR (or was that the sound of one hand clapping?) |
| Old meets new but can this be solved? | barchetta | Pass Labs | 4 | 11th March 2007 07:29 PM |
| Old Meets New | philipbarrett | Tubes / Valves | 3 | 22nd August 2005 12:03 AM |
| Page generated in 0.10584 seconds (82.67% PHP - 17.33% MySQL) with 11 queries |
