Old 15th December 2008, 01:58 AM   #41
mfc is offline mfc  United States
Default hibias input
The higher bias reduces all the higher harmonics (H3...)
at 20Khz. Attached is a FFT at 45Vout into 4ohm.
The second is down 126db below the fundamental, and
the other harmonics are 20db below that.
THD at this level was .5ppm
Old 15th December 2008, 02:02 AM   #42
Finally,
It looks like it also helped increase the slew rate.
Attached is a 100Khz square wave 45Vout into 4ohm.
Not a world record, but certainly fast enough.
Thanks!
File Type: gif 12th_hibiasinput_square_45vout_100khz.gif (16.3 KB, 232 views)
Old 15th December 2008, 06:41 AM   #43
Banned
Mike,
looks much better to me, I would increase the current in Q18 by changing the value of R37/44 to say 330Ohm.
Do you have a link to a data sheet for ECX10N18?
Old 16th December 2008, 02:32 AM   #44
The darn data sheet is too big. Send me your email and I'll
send you a datasheet. I'm using the EC20N20/20P20 which is
the same thing just a little bigger.
A 2SK1058/2SJ162 woud do as well, although R42 and the
gate stoppers might need a little tweaking.
Thanks,
Mike
I'll play around with tweaking the current on the input CFP
transistors.
Old 21st December 2008, 06:13 PM   #45
Originally posted by darkfenriz
Keep in mind that mosfets in reality are only slightly faster than bipolars.
I have to diagree a bit.
In most cases vertical power MOSFETs are much faster than even RET BJTs. This is not so much the case for Lateral MOSFETs, to which you might have been referring.
The NJL3281 RET BJT has a peak ft of 50 MHz at 2A, but this falls to 20 MHz at a typical 100 mA bias point. It also suffers from ft droop at high collector current, as do virtually all BJTs. Its ft falls to 20 MHz at a collector current of 5A with 5V collector to emitter. It falls below 5 MHz at a collector current of 10A.
The IRFP240 has an ft of 74 MHz at a typical bias current of 150 mA. Its ft gets up to about 300+ MHz at currents above 1 amp.
Collector-base capacitance for the NJL3281 is about 400 pF at a reverse voltage of 5V, while the IRFP240 drain-gate capacitance is on the order of 500 pF at a drain-source voltage of 5V.
Bob
Old 21st December 2008, 09:42 PM   #46
darkfenriz's Avatar
Hi Bob
I was refering to a device made 'dead stable' on any occasion. In my experience using bjts makes things easier to stabilize, so that you often end up with a mosfet stage only slightly faster then similar bjt stage.
I know you were using some nice snubbers to squeeze out more speed and achieve good stability, but that's still a trick, isn't it?
Adam
Old 22nd December 2008, 12:41 AM   #47
Hi Bob
Adam
Hi Adam,
You make a good point. MOSFETs, largely due to their higher ft, do have a greater tendency to local parasitic oscillations. Indeed, in this regard, they sometimes require more skill to apply, especially if their full potential is to be realized. I do cringe a little when I see big gate resistors used to stabilize them. BTW, gate stopper resistors used with BJTs also tend to have the same effect.
A related speed issue is the amount of current that one has to pull out of the base or gate of a heavily turned-on devive to turn it off or to cause it to slew at a given rate of current change. The MOSFETs tend to do better than BJTs in this regard as well.
Bob
Old 9th January 2009, 02:45 AM   #48
Default tune 2nd and 3rd
Using a clue from OStripper (thanks), here is better front-end
performance then what was there before.
This tweaks the values of the specified resistors to all but
eliminate 2nd and 3rd order distortion components.
Total THD 20Khz into 4ohm 45v peak = 0.00001%
or > .1ppm.
The current through the NPN/PNP transistors are close to
the same 1.8ma/2.1ma. You may recall, I increased the
current in the LTP to improve the slew rate.
I know it will never be this good in reality.
Mike
Old 9th January 2009, 03:38 AM   #49
andy_c is offline andy_c  United States
Banned
Here's a few questions:
What happens to the collector current of Q7 when in the positive half cycle of clipping, and why? How do you fix it? (Make sure you overdrive it enough in the sim to check this).
You'll also need a real current source for the VAS in order to look at clipping for the negative half cycle. With an ideal current source here, it's more of a concept than a design. Of course, input stage current sources are a non-problem, so this statement doesn't apply there. But the VAS current source is critical and a key part of the design.
Old 10th January 2009, 06:10 AM   #50
Hi Andy,
I haven't found either of the current sources to be too critical to
this.
But yes, the picture during clipping look a little ugly...
I find the problem originates with the driver (MOSFET) around
a Vin of 3.959v.
It plays havoc with the VAS current demands.
Couple of thoughts to help the VAS with recovery...
1) Remove the VAS current source entirely and replace it with a
bootstrap consisting of two 4K resistors and a 2.2uF cap.
Replace the VAS current source with the two 4K resistors.
Connect the 2.2uF cap between the junction of the 4K resistors
and the output.
2) Add local feedback resistors of ~50K between the gate and
drain of the driver FETs. This helps the VAS momentarily
keep up with the current demands on it.
I like 2) because it also improves the driver linearity during
normal operation by providing local feedback.
What are your thoughts?
Thanks,
Mike
Gain Blockwith Variable Loop Gain Bonsai Solid State 17 11th July 2008 02:40 PM
open loop gain,how many is enough? Leolabs Solid State 28 17th May 2006 09:00 PM
Loop gain question lumanauw Solid State 55 16th December 2005 09:59 PM
Gain loop formula fscarpa58 Everything Else 2 16th January 2004 11:19 AM
Open loop gain (High or low) ? JensRasmussen Solid State 19 16th September 2002 09:26 PM
Page generated in 0.14507 seconds (71.61% PHP - 28.39% MySQL) with 11 queries
