I have a 230 volt version of the Bryston BP-20. The attached picture shows the transformer section of the power supply. Is it possible to re-wire this to support 115 volt US current?
I'm assuming that for 230v, points J3 and J4 (unlabeled) are wired together from the transformer. I'm also assuming that for 115v, points J2 and J3 are wired together. Also, J1 and J4 are wired together. This looks pretty simple, but what is the F1 component before S1 (switch)? It looks like there are two different values for 230V and 115V configurations (150maSB or 250maSB). Can someone help shed some light here? |
#2 |
F1 is a fuse; it limits power, which is P=U I, so for twice the voltage (230 vs 115) one uses a fuse for half the current, so that the product, the power, stays the same.
Have fun, Hannes
fresh matched IRFP240/IRFP9240 fets || AlephJ/JX-kitsF5 transistor kits || Burning Amp BA-1/2/3 transistor kits |
#3 |
Excellent! Thank you.
#4 |
hi
to clarify omit j3, connect j1 and j2 as shown in blue, for 115V operation
regards bob |
#5 |
Hi Bob,
Thanks for clarifying. That is what I assumed. |
#6 |
h_a
You can't just change a fuse and expect it to operate at a different voltage. The primary windings of the transformer need to be either paralleled for 115VAC operation or series connection for 230vac operation. Normally you would have 2 x 115vac primary windings on a transformer for 115 or 230vac operation. Changing just the fuse would still mean the mains voltage would still get to the transformer EVEN if you did not do anything to the primaries. Bad if you have a 115vac unit and plug it into a 230vac supply!! |
| Case: Naka RX-202 120V to 230V convert | PaleRider | Everything Else | 3 | 13th February 2009 05:50 AM |
| Convert 230v Breville juicer to 110v | newb | Everything Else | 11 | 10th January 2009 06:33 AM |
| Convert 110v to 230v input ? | istari knight | Digital Line Level | 6 | 1st January 2009 07:41 PM |
| Question about autotransformer ( 230V to 115V ) | Rodeodave | Power Supplies | 5 | 4th June 2007 01:11 PM |
| 115v conversion fro 230V Cambridge Audio CD4 and Dacmagic 2i | taskerc | Digital Source | 4 | 7th February 2006 07:02 PM |
| Page generated in 0.09592 seconds (69.49% PHP - 30.51% MySQL) with 11 queries |
