I opened up my Marantz pm-80 to build a preamp-out connection.
Parallel to all input connections i discoverd 103's ceramic capacitors. Is it benefitial to the soundquality to remove them or to change them to film? Any drawbacks if i remove them? |
#2 |
Banned
Marcelinho,l
I would definitely omit them. |
#3 | |
Large disc ceramics are very non linear but smaller ones are actually not as bad as many people believe. The main purpose of the caps will be to prevent RF entering and causing parasitic oscillations or degraded performance. You could change them to polystyrene or polyester film types but I would also be inclined to reduce the value from 10n to 1n. The reduced capacitive load on the driving source will probably have more effect on THD than changing the type of capacitor. Unless you live in an area with very high levels of RF pollution then 10n is overkill. |
#4 |
Marcelinho
I omit such caps at the input. If you have an rf problem them reinsert as advised above. Don |
#5 |
Thanks!
I can try them all. I have enough inputs for dubbelblind testing. The old situation, without a cap, or with a smal filmcap. I don't expect a huge difference but while it's open...... |
| [SG3525 smps] Input capacitors puffing after adding snubber | aliazhar | Power Supplies | 36 | 21st November 2009 08:59 AM |
| Why did Marantz use 4 capacitors for coupling? | bleachershane | Digital Source | 4 | 5th April 2009 11:04 PM |
| what is the difference between silver mica capacitors and ceramic capacitors ?? | prorms | Solid State | 1 | 6th May 2008 12:38 PM |
| Aleph-x input-coupling-capacitors | oliverniekamp | Pass Labs | 14 | 7th May 2006 08:43 PM |
| 5R4WGY/A/B , input filter capacitors | riccardo | Tubes / Valves | 12 | 26th July 2005 09:08 PM |
| Page generated in 0.09142 seconds (70.25% PHP - 29.75% MySQL) with 10 queries |
