Old 8th December 2008, 03:58 PM   #1
Question [enquiry]Compression IC NE570 compandor
Hello everyone,
Im currently doing a project to develop a hearing aid system.I goin to use NE570 compandor as a compression circuit but im confuse how to implement the IC.The 16 pin really confuse me since im lack of reference.Can anyone guide me to this?
Old 8th December 2008, 04:29 PM   #2
Khron is offline Khron  Romania
Send a message via AIM to Khron Send a message via MSN to Khron Send a message via Yahoo to Khron
I believe the datasheet of the NE570 is more or less "self-explanatory". It seems to contain all the calculations you need, you just have to decide on some time and/or component values.
Old 8th December 2008, 05:38 PM   #3
I got what you mean. But im really need some example on implementation of NE570(schematic).Im confuse here.
Old 8th December 2008, 05:50 PM   #4
How about the application notes ??
Old 8th December 2008, 06:02 PM   #5
lineup is offline lineup  Sweden
lineup's Avatar
Search google images: http://images.google.com/
Keyword: NE570
You will find more schematics than you need
lineup
Old 8th December 2008, 06:38 PM   #6
Keyword: NE570
Haha i had try on that That bring me the issue on this forum.
Old 8th December 2008, 06:38 PM   #7
Still learning Im confuse about gain cell pin(3,14).
Old 8th December 2008, 07:32 PM   #8
lineup's Avatar
I think you should study and setup a basic compressor (Fig.7)
and one basic expander (Fig.6), from the NE570 datasheet.
What I understand the compressor can be set to some Gain.
And the Expander will take the compressed signal and put it back for normal use.
The application note pdf is also useful (I think)
Applications for Compandors NE570/SA571
http://www.onsemi.com/pub_link/Collateral/AND8159-D.PDF
lineup
Old 8th December 2008, 07:36 PM   #9
lineup's Avatar
The gain cell is where it happens.
Based on the RECT_IN (a rectified signal level)
the gain cell will adjust the gain to required gain level.
If the RECT_IN is fed (getting feedback) from the output, and the output level is very low
then the RECT_IN will tell the gain cell to provide more gain
and so the signal at output gets stronger.
lineup
Old 4th May 2011, 02:59 PM   #10
opikbdg is offline opikbdg  Indonesia
Talking try ne578
Originally Posted by elnino86 View Post
Hello everyone,
try
http://www.icbase.com/pdf/PHI/PHI08040106.pdf
the ne578 are more easy to understand..
cheers
Compression ratio and diaphragm size in compression drivers inkasound Multi-Way 50 8th January 2009 03:38 PM
[enquiry] Treble Boost/High frequency Boost circuitry elnino86 Parts 2 18th December 2008 12:33 PM
compression? kathodyne Tubes / Valves 17 11th April 2005 08:56 AM
Air compression Raka Pass Labs 27 9th November 2002 09:32 AM
Page generated in 0.10634 seconds (79.07% PHP - 20.93% MySQL) with 10 queries
