Symasym PCB
Symasym PCB
Old 8th December 2008, 12:22 PM   #41
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
They don't hurt. They can increase stability and for this amp, that's a good thing
Another suggestion: There isn't a need for the ground plane you have there. You could run wide traces back to the star, especially from the 2 bigger caps on the output stage. Right now, the front end decoupling ground trace is wider than the output decoupling.
Also, look at making the output trace wider. This carried all of the current the amp provides.
Old 8th December 2008, 12:54 PM   #42
Khron is offline Khron  Finland
Send a message via AIM to Khron Send a message via MSN to Khron Send a message via Yahoo to Khron
Thanks again for the tips Here's revision whatever-it-is
Old 9th December 2008, 11:39 AM   #43
So... is this last iteration good to go?
Old 9th December 2008, 11:45 AM   #44
roender is offline roender  Romania
roender's Avatar
Move some components ...
Old 9th December 2008, 11:57 AM   #45
lineup is offline lineup  Sweden
lineup's Avatar
My guess is that roender thinks about keep a distance
between hot power transistors and heatsink and the electrolyt capacitors.
Higher temperatures will shorten the life of lyt-caps.
lineup
Old 9th December 2008, 12:01 PM   #46
MJL21193's Avatar
I think it has more to do with the shortest path to ground form the highest source of current on the board.
Old 9th December 2008, 12:02 PM   #47
roender's Avatar
Yes and no. The main reason is to keep as small as possible the ground line between decoupling capacitors, as that line is highly polluted with half waves rectified output signal
Old 9th December 2008, 02:30 PM   #48
Well, this is about as close as i could get them to the middle (within practical limits)...
Old 9th December 2008, 02:54 PM   #49
roender's Avatar
One more step ...
Old 9th December 2008, 04:11 PM   #50
"One more step" accomplished, cap'n
Symasym PCBHide this!Advertise here!
Troubleshooting your Symasym anatech Solid State 236 14th April 2015 02:47 AM
FS 2* DIY Symasym boards Andypairo Swap Meet 11 1st February 2009 01:59 PM
symasym 5_3 boards traw Swap Meet 6 11th May 2007 09:41 AM
