Old 5th December 2008, 09:15 AM   #1
tadiam is offline tadiam  Argentina
Send a message via AIM to tadiam Send a message via MSN to tadiam Send a message via Yahoo to tadiam
Default any idea?
Have an +/- 22v power supply an 4 - 10.000 uf cap (two per channel).. need an recomendation
power amp schematic for this power supply.
20/25w per chenel good sound and elaborate schema..any idea?
audio
Old 5th December 2008, 09:20 AM   #2
AndrewT is online now AndrewT  Scotland
try ESP for a discrete design.
or any of the chipamps, particularly Nuuk's (Decibel dungeon; http://myweb.tiscali.co.uk/nuukspot/decdun/).
regards Andrew T.
Old 5th December 2008, 11:12 AM   #3
Default re
lm1875,lm3886 build this...no chips thanks
audio
Old 6th December 2008, 05:25 PM   #4
djk is offline djk
djk's Avatar
http://www.passdiy.com/pdf/a40.pdf
Circuit boards available from AudioXpress.com for $6.
May be adapted to use locally available transistors, or run class AB.
Candidates for the Darwin Award should not read this author.
Old 6th December 2008, 08:01 PM   #5
ostripper's Avatar
I read this post a couple of days ago and ported my two amps
for operation at +- 22v.
With just a change of 2 resistors I was able to get premium
performance at 35w/8r using a single cheap pair of NJW0281/
0302.
Final price for this was about 14$ per amp (mouser) but
what you get on a 3X3 PCB is a .08% distortion "blameless"
that sounds the same as its "big brothers" ,the FA1/ FA2.
No "threadjacking' here, but the design is being tested
with much abuse...
would be a sleeper to post a "mini frugalamp1" for any
interested...
OS
Old 7th December 2008, 09:01 AM   #6
Default re re
thanks ostripper and djk ...and al diys
audio
Different pre amp idea bartek Solid State 3 25th March 2008 03:42 PM
I really have no idea what I'm doing here... d to the g Multi-Way 10 7th March 2008 06:04 PM
P.S idea noyan Power Supplies 15 19th December 2007 08:50 PM
An idea! Fully balanced TDA1541A DAC idea. Please comment! cartman Digital Source 8 17th July 2007 08:18 AM
Just an idea bob123 Subwoofers 4 9th April 2006 02:28 PM
Page generated in 0.09667 seconds (76.60% PHP - 23.40% MySQL) with 10 queries
