PGA2310 "how to" - Page 4 - diyAudio
Old 25th December 2008, 09:56 AM   #31
johnYks is offline johnYks  Australia
Hello day1118
This site is very thorough and detailed, it should
be of use to you.
http://www.mhennessy.f9.co.uk/audio.htm
Read the following pages
http://www.mhennessy.f9.co.uk/pic/index.htm
The project that he has built should also be of use - read this
http://www.mhennessy.f9.co.uk/preamp/analogue.htm
Hope this helps.
Yours Sincerely
John
PS
Happy New Year!
Old 25th December 2008, 03:34 PM   #32
danzup is offline danzup  Romania
danzup's Avatar
Default Pga 2310 Pga 2311 Pga4311
Hello ,
Here are the schematics and software write in Bascom.
If you need help please ask .
I have help a lot o people (from the link of the forum provided by alexmm , as I am the author ) to build this and all of variant for audio controller (audio controller for All type of PGA , volume controller with alps pot with motors , audio controller with ladder r/2r).
The soft is somewhat commented but for more info just ask !
Any type of RC5 remote is ok .
I have commented where to change software to suit your remote .
Also I have write a small program that detect code on your remote and then is easy to edit software to put the right key code(if you are in need for such software just ask ).
There are not better tube than 6P3S and 6N2P for my ears !
Old 25th December 2008, 03:35 PM   #33
rhysh is offline rhysh  United Kingdom
rhysh's Avatar
Send a message via MSN to rhysh
There is no software attached..
Also, what remote control standard is used?
Rhys
Old 25th December 2008, 03:38 PM   #34
danzup's Avatar
Default schematic
This forum do not accept more than 1 attach , so here are the schematic.
The project is simple and do not need microcontroller knowledge . As for directions I am here to help ...
This variant is with encoder and 2 switches n/off and menu .
The first switch do what the name say and the second switch is for toggle between volume and input source for the command with rotating encoder .
I have done also different variant for input (and different software ): one with 5 switches for people who do not like encoders (Input - , Input + , Vol - , Vol + , on/off) and even a variant with 2 encoders ne for volume and one for source input select .
Old 25th December 2008, 03:52 PM   #35
danzup's Avatar
http://i40.tinypic.com/vrscb9.jpg
http://i42.tinypic.com/2hicmkh.jpg
http://i41.tinypic.com/wiof34.jpg
http://i42.tinypic.com/t7h947.jpg
http://i44.tinypic.com/4hpbis.jpg
http://i43.tinypic.com/2pquc8x.jpg
http://i43.tinypic.com/5vwqb7.jpg
If you need another controller please open a new thread and I will provide schematics an software including source .
Old 24th July 2010, 09:34 PM   #36
jash2008's Avatar
This what I was looking for.
Thanks alot.
could you please post/send me some higher resolution schematics like one in pdf format.
my email: akjain2007@dataone.in
Old 25th July 2010, 10:34 AM   #37
I haven't done control of a PGA2310 yet, but I am a software engineer and have played about with an AVR before
Forget the PIC, they're horrible little microcontrollers from the 70's and a pain in the *** to program. The instruction set is nasty. The Atmel AVR costs only a little more, has a much nicer instruction set - and as a bonus, because it is a well implemented micro, there is a port of the GCC compiler to it, so you can write in C without having to spend a fortune on a commercial compiler. Atmel also have many tools for free, and lots of example code - one of which is a remote RC-5 protocol decoder
Rather than trying to do everything at once, take it in stages and build up modules. For example, if you want to write to an LCD, figure out routines for setup and control of the LCD first. Once you've got a routine that initialises the LCD, and allows you to write any characters to it, move on.
The PGA2310 uses a protocol called SPI - a very simple serial protocol. Another advantage of using an AVR here is that most of them have hardware support for SPI. PIC's typically have to "bit bang" this, which makes it a little harder to program.
Controlling relays can be done the obvious way, by using IO pins as outputs and then switching transistors. If you're a little more adventurous, you can save precious IO pins by using a shift register, which you can write to with the SPI port. TI make a great chip called the TPIC6C595 which is an 8-bit shift register with built in MOSFETs for power switching. You can also use the same chip for driving LEDs.
Old 25th July 2010, 11:10 AM   #38
I'll second that. I'm not a software engineer, but have built many successful AVR projects with ease. There are numerous code libraries and free examples for interfacing AVRs with LCDs and SPI devices. The compiler and programming tools are free for both Windows and Linux.
To program the devices, perhaps the simplest method is to use a PC parallel port (if you still have one) and build an interface using just four resistors. A helpful forum providing assistance, code examples and user projects may be found at: AVR Freaks
Steve
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 07:42 PM
Charcoal "Supreem" hi-density foam "enclosure" IG81 Multi-Way 0 23rd April 2009 02:34 PM
"Void free" or "no core gaps" plywood rick57 Multi-Way 6 14th March 2007 02:09 PM
Some final pics of "Stacks" revisited and "Askew" with stand Andy G Multi-Way 2 3rd February 2005 07:07 AM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 09:42 AM
Copyright ©1999-2017 diyAudio
