PGA2310 "how to" - Page 3 - diyAudio
Old 11th December 2008, 11:20 AM   #21
rhysh is offline rhysh  United Kingdom
rhysh's Avatar
Send a message via MSN to rhysh
Default Re: Help along the way
Originally posted by ALBQ
rhysh,
Check the following thread Cheers -ALBQ
DIY Remote Control for Everyone
Thanks for the link! Can i just confirm the source code works, and the schematics fit the source code? Also, what remote control protocol are you using??
Thanks!
Old 11th December 2008, 12:11 PM   #22
yangsmm is offline yangsmm  South Korea
Default Re: Re: Help along the way
Thanks!
I think. it is useul..It can be controller by remote controller and PC-Based Program.^^ It is also controlled by Rotary-Encoder.
Balanced Audio Volume Controller with PGA2310
Old 11th December 2008, 01:01 PM   #23
Default Remote Control info
I had gathered some information on remote controls when I was working on my PGA4311-based preamp. See the briefing in the link:
Remote Controls
Hope it helps...
I've got code for the PGA4311 chip, but it is a bit cryptic because I used the chip as a mixer, and there is a lot of on/off logic in addition to straight volume. Also, it is written in 6808 assembler, which isn't a very popular environment. The LCD is a graphical display, so none of that code would help you.
Old 12th December 2008, 11:24 AM   #24
ALBQ is offline ALBQ  United States
Default Confirm Code
rhysh,
Yes, I can confirm the code works. Is really just an extension of code from my current preamp - in regular use for the last four years. IR signal code is for a universal remote. I forget but, think it is program #002 on a RCA univeral remote.
Best of luck -ALBQ
http://home.comcast.net/~gillespie147/12AU7-Preamp.html
Old 12th December 2008, 11:25 AM   #25
rhysh's Avatar
Thanks, does it work on any other microcontroller? Basic Stamps are a bit obselete and hard to find.
Rhys
Old 12th December 2008, 11:32 AM   #26
Default Code
rhysh,
Code can easily be adapted to work on most PIC microprocessors using PIC Basic - at the heart of a basic stamp (BS2), is a PIC. Will need to play with timings a little for IR decode but, not a problem.
Hope this helps -ALBQ
Old 24th December 2008, 11:32 AM   #27
day1118 is offline day1118  Australia
Hey guys, I still havnt got my PGA2310 working. Does anyone have some example code I can look at please???
Atm Im not using an LCD or remote, just trying to get the volume control to work. I have done a bit of work recently with Assembly, so now have a reasonable understanding. I am using a PIC16F628.
If anyone has any code, Id really appreciate being able to have a look at it!
Old 24th December 2008, 02:26 PM   #28
m2003br is offline m2003br  Brazil
hope this help:
http://www.dh3ben.de/html/electronic...1_preamp.shtml
cheers,
Marcos
Old 24th December 2008, 05:50 PM   #29
alex mm is offline alex mm  Romania
alex mm's Avatar
Default or this link.....
maybe this link will help to http://www.elforum.ro/viewtopic.php?...sd=a&start=315 Regards alex mm and Merry Christmas !
L.E. my source selector and volume control with LCD display http://i41.tinypic.com/bfypv.jpg
Old 24th December 2008, 09:31 PM   #30
Thanks alex and M2003br, Ill have a look tonight!
Merry Christmas, Thanks
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Charcoal "Supreem" hi-density foam "enclosure" IG81 Multi-Way 0 23rd April 2009 01:34 PM
"Void free" or "no core gaps" plywood rick57 Multi-Way 6 14th March 2007 01:09 PM
Some final pics of "Stacks" revisited and "Askew" with stand Andy G Multi-Way 2 3rd February 2005 06:07 AM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 08:42 AM
Copyright ©1999-2017 diyAudio
