PGA2310 "how to" - Page 2 - diyAudio
Old 3rd December 2008, 04:14 PM   #11
rhysh is offline rhysh  United Kingdom
rhysh's Avatar
Send a message via MSN to rhysh
Originally posted by rtarbell
"I cant do this. I have tried and tried with assembler but i cant get it to work, all i am trying to do is switch a relay on and off with a remote control string, and have its status displayed on the screen."
Do you have an oscilloscope available to see your data signals? What PIC microcontroller are you using? An oscilloscope would be nice to see the data being sent to the PGA2320.
For my project, I have 8 buttons on the front panel of the unit (“local buttons”), and then the “same” 8 buttons on a remote control. Does your unit have local buttons on the front panel as well? I would get these local buttons working before I tried to get the remote control working. If you are getting messages to display on your LCD, then it sounds like you have the correct underlying functions, so that’s a great step in the right direction!
I do not have a scope at this current time, there is no way i can afford to get one of any kind unfortunitly . I am using the AVR ATtiny2313 microchip for this project, as i have never a dev station on hand.
Are you coding your project in C?
To start off with, i am trying to get a push button, connected to a I/O pin directly, to toggle a relay on / off that is also directly connected to a I/O pin, and have the status displayed on screen, can you point me in the right direction (Im a C noob!)
I have no plans to implament local buttons at the moment, as i am trying to keep everything neat and tidy.
If you dont mind, would it be possible for me to have a look at your source code so far (not to copy you, or sell your idea) just to get a insight on what is going on. My email address is rhysATpressure-drop.org (@) if this is okay with you?
Thankyou!
Old 4th December 2008, 05:43 AM   #12
day1118 is offline day1118  Australia
Hi guys, Im still after an example that explains how the serial communication is done please. If anyone has an example/their own code, or knows where I can find one could you please let me know.
(Any language would be fine!)
Old 5th December 2008, 04:54 PM   #13
Hey guys,
Sorry about the delay - I haven't forgotten about it, I'm just trying to find the code project, and "spruce" it up a little so that it's readable. I wrote it in Microchip's C18/MPLab compiler, so it may not make entire sense to someone using Atmel and the AVRs (GCC compiler probably?).
One nice thing about the C code itself, is that C code is C code (unlike assembly, which can vary widely between microcontroller makers!).
Old 5th December 2008, 05:08 PM   #14
rhysh's Avatar
Hey guys,
Hi, i am very intrested to see this code! Keep us up to date!
Rhys
Old 6th December 2008, 06:36 AM   #15
Thanks.
Im still not having any luck, moved to a computer parellel port and VB cos i know the language reasonably well, but still no luck!
Ive noticed that the PGA2310 gets quite hot in a reasonably short amount of time, anyone else found this?
Old 6th December 2008, 06:47 AM   #16
Also, I just found that I didnt have the right Analog ground connected to anything (Im only working with Right channel atm), but when I connect it, I lose all music, and it sounds like a mix between air and a growling sound!
Any suggestions anyone?
*Cant find shorts or any other problems, but for the moment have disconnected everything on pins 2,3,6,7 til I work out whats going on with the heat and ground connection!
Old 7th December 2008, 01:27 AM   #17
Okay! See the attached file for an example of my LCD routines. They are very basic, but I have verified that they work. Like I said, these routines I wrote for the PIC 18F2321, so all of the included files (linker scripts, libraries, etc.) are using MPLab and the C18 compiler. You can get both for free from Microchip's website.
Old 7th December 2008, 07:01 AM   #18
rhysh's Avatar
Thankyou ever so much for sharing this, do you have the schematic for your dev board / whatever you are using to test this?
Rhys
Old 7th December 2008, 09:14 AM   #19
rhysh's Avatar
I have cracked it, with a rotary encoder and without a remote and lcd! No more sucess after that! Im not sure how to display the current gain on the lcd...
Old 11th December 2008, 11:01 AM   #20
ALBQ is offline ALBQ  United States
Default Help along the way
rhysh,
Check the following thread Cheers -ALBQ
DIY Remote Control for Everyone
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Charcoal "Supreem" hi-density foam "enclosure" IG81 Multi-Way 0 23rd April 2009 01:34 PM
"Void free" or "no core gaps" plywood rick57 Multi-Way 6 14th March 2007 01:09 PM
Some final pics of "Stacks" revisited and "Askew" with stand Andy G Multi-Way 2 3rd February 2005 06:07 AM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 08:42 AM
Copyright ©1999-2017 diyAudio
