I haven't got enough transistors to perfectly match all four transistors in the improved Wilson CM. Does it matter if one of the pairs have higher Hfe? Should the transistor pair with higher Hfe be at the "bottom" or the "top"?
#2 |
As the CM is degenerated with the 68R resistors HFE matching has some room for mismatch, as for top or bottom its up to you as this would come down to personal preference. Discreet AD797 i see?, the second post with the DB output stage gave it away
Colin |
#3 |
HOLA Y'all,
I would like to see the rest of the schematic, the front end looks interesting... Regards, Elwood
"when you open your mind to the imposible, soon you will find the truth...." |
#4 |
nelson,
That is almost the same circuit I have used. The lower transistors are probably more critical but I would replace them with similar types when you can. How do you like the sound? Jam |
#5 |
Wow, 4t on bottom and a 3T on top..
. I'm about to buildsomething similar with 'frugalamp 2' and have simmed the hell out of it with a 3 and 4T on the bottom CM. With just a 3t (final choice) on the bottom CM I couldn't get much unbalanced operation with even grossly mismatched Re's. I then simmed with different devices (for the hell of it) and by adjusting [Rj] brought it back in balance again. BtW like your input.. might try fet input or OPS in future.. OS |
#6 | ||
As for the sound it fares very well compared to the original AD829 and AD797, but I'm probably biased. The choise of transistors is very critical when it comes to sound quality. With BC550/560 it's worse than the monolithic amps, but with those Sanyo's it sounds perfect to my ears - warm and full yet with all the details and authority. With Toshiba SA970/SC2240 the quality is the same, but I find it to bright. I've just found out that it sounds better with ONSemi's BD137/138 vs Sanyo SC3953/SA1538 as output transistors. I had such high hopes for the latter .
#7 | |
#8 |
What a lovely preamp. Is it class A?? At least you show schema,
unlike J. Curl ... will sim. Thanks..
#9 | |
#10 |
Have you built it , or only simmed..??
Will it run on +-12v (+- 5 is kind of low)? |
| Current mirror for the aleph? | 3nity | Pass Labs | 10 | 4th June 2009 08:02 AM |
| Current Mirror: The V-mirror | rtarbell | Solid State | 1 | 19th November 2008 02:27 PM |
| Cascode VS Wilson Swapped Mirror | TzeYang | Solid State | 4 | 9th July 2008 03:24 PM |
| no current mirror, current mirror, cascoded current mirror, bjt or jfet VAS? | maxpou | Solid State | 31 | 17th June 2008 04:31 PM |
| Current mirror | abzug | Solid State | 7 | 1st January 2008 07:03 PM |
| Page generated in 0.11054 seconds (77.07% PHP - 22.93% MySQL) with 11 queries |
