Old 29th November 2008, 10:04 AM   #1
lazenna is offline lazenna  Australia
Default B&O 1000asp amplifiers
Hello diy'ers.I wonder if anyone can tell me whether these modules from B&O can just be wired up to the appropriate connectors and used.I notice that on some of the commercially available equivalents eg:JeffRowland 501 and some others that even to put a led on the front panel they have some type of circuitry.
Old 30th November 2008, 02:08 AM   #2
cyril_hk's Avatar
Default This one?
http://www.icepower.bang-olufsen.com...ker/ASP_SERIES
Old 30th November 2008, 09:59 AM   #3
Yes Cyril they are the one's.
Old 30th November 2008, 11:16 AM   #4
cyril_hk's Avatar
Here the data sheet...
http://www.icepower.bang-olufsen.com...000aspdata.pdf
and from what the photos can tell, yes you have every connectors you need on the module. it even came with it own switching psu!
http://magusmax.pixnet.net/blog/post/21653083
Old 30th November 2008, 08:14 PM   #5
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
Default Re: B&O 1000asp amplifiers
In a word, yes. The problems are that the input impedance is a low-ish 8kOhm which some preamps may not like and that the gain is only 27dB meaning they require quite a lot of voltage for full power compare to other amps. Most of the commercially available amps will use input circuitry to raise the input impedance to around 50kOhm and provide a bit of extra gain as well.
/U.
Old 1st December 2008, 05:32 AM   #6
Do you know of any simple small circuits that I would be able to use.Thx
Old 1st December 2008, 10:35 AM   #7
What does the Lundahl transformer do?
Old 1st December 2008, 11:40 AM   #8
cyril_hk's Avatar
That is a input transformer
http://www.lundahl.se/pdfs/datash/7901_02.pdf
Old 1st December 2008, 02:58 PM   #9
h_a is offline h_a  Europe
h_a's Avatar
8k is a nice input impedance and not a problem for solid-state preamps. Nothing wrong with that, why put some jfet follower in front to get it higher?
Have fun, Hannes
Icepower 1000ASP Module 1 new +1 for sale maxzimum Swap Meet 1 13th August 2009 05:16 AM
IcePower 1000ASP Wanted toufu Swap Meet 0 8th July 2009 11:59 PM
Power switch for B&O 1000asp. lazenna Solid State 1 7th January 2009 04:42 AM
Ice power 1000ASP Sundance Class D 2 25th September 2006 07:29 AM
WTB:ICEPower 1000ASP/500ASP chengtaw Swap Meet 0 23rd March 2006 01:22 AM
Page generated in 0.11249 seconds (70.31% PHP - 29.69% MySQL) with 10 queries
