Old 27th November 2008, 07:45 AM   #1
roender is offline roender  Romania
roender's Avatar
Default Suitable jfet for an zero GNFB amp?
Characteristics:
low noise
Yfs > 10mS
zero Ids (Vgs) drift with temperature at any current in the range of 2...8mA
There is such device?
Old 27th November 2008, 08:44 AM   #2
h_a is offline h_a  Europe
h_a's Avatar
2SK170/2SJ74
2SK369
However there's no data on temperature dependence of drain current in the datasheet.
Have fun, Hannes
EDIT: I just saw your RMI-amp uses the 2SK170; so what is your particular interest, the zero tempco for ID? I don't remember that spec in any jfet datasheet, but I only have the abbreviated pdfs.
Old 27th November 2008, 08:48 AM   #3
I don't think this will have 0 tc Too much transconductance. You need about 0.7V bias voltage to get 0 tc, and a 170 will not get you there easily.
Old 27th November 2008, 08:56 AM   #4
roender's Avatar
Zero Tc for k170 is at 13...14mA but at this current is has very high transconductance and it not sound good.
Old 27th November 2008, 09:50 AM   #5
bogdan_borko's Avatar
Default Re: Suitable jfet for an zero GNFB amp?
Originally posted by roender
Characteristics:
low noise
Yfs > 10mS
I don`t think you`ll easily find a jfet like that.
btw. I`m working on non-global-feedback amplifier and I`m using 2SK170BL/2SJ74BL in the input stage but with servo incuded.
Old 27th November 2008, 10:01 AM   #6
roender's Avatar
Linear Systems j308/j309/j310 maybe?
Old 27th November 2008, 11:03 AM   #7
homemodder's Avatar
Roender, you have mail, let me know if it works out.
Old 28th November 2008, 12:56 AM   #8
Banned
Roender,
zero Ids (Vgs) drift with temperature at any current in the range of 2...8mA There is such device?
There is not (on this planet).
Old 28th November 2008, 10:25 AM   #9
AndrewT is online now AndrewT  Scotland
Feucht wrote a paper on temp coef of Jfet.
I seem to recall he said the Vgs should be 800mV above Vpinchoff for closest to temp comp.
Then the CCS is set up to ensure it too has temp comp at the required current.
regards Andrew T.
Old 28th November 2008, 11:36 AM   #10
roender's Avatar
VGS = VP + 0.63V for zero TC
http://www.tkhifi.com/div/Erno_Borbe..._articel_1.pdf
GNFB and distortion myhrrhleine Solid State 16 29th July 2008 05:55 PM
Can I replace BF245C JFET with J201 JFET? bigmike216 Parts 2 7th December 2005 06:50 AM
Suitable regulated/filtered 4volt battery-valve power supply suitable for 6+ valves? Layberinthius Tubes / Valves 0 11th March 2004 08:49 PM
Page generated in 0.09640 seconds (75.33% PHP - 24.67% MySQL) with 10 queries
