I'm looking for a good Square Wave oscillator, that I can build.
It's needed for testing standard audio frequency appliances , and for checking D/A converters.I'd like to have a super clean shape...no rounded or peaked edges, and, level and ...well you know.......square. Although I have not yet tried a 555 timer, someone told me a flip-flop and a buffer would be much better. ....or is it possible to stick something on the output of my low distortion sine generator ? =RR= |
#2 |
#3 |
Thanks ostripper .
However, I may be wrong, but I have my doubts that the square emanating from an opamp, will meet my desire for a "true" sharp square. I could try it....looks easy. =RR= |
#4 |
op-amps slew rate is only limiting factor, it is most likely
better than most SS amps. A better op-amp (ne5534) ,would beat many audio amps in slew rate. |
#5 |
a comparator would be better still. They are designed to change state fast.
regards Andrew T. |
#6 | |
#7 |
741 = 1v/uS
NE5534 = 13v/uS "blameless" amp = 10-20V/us before optimization ( from book-D.self) consumer ht receiver= rarely more than 15v/uS audiophile amp (and our DIY amps) 30-40v/us heck, use a max477 op-amp w/ 1100 v/us slew but at audio freq. above circuit w/ hysteresis will give very square wave. |
#8 |
If you look at some of the graphs that Nelson puts out for, say, the F5 amplifier, he is illustrating bandwidth with a 200kHz square wave. That's pretty brutal on any audio amplifier.
A standard, government issue multivibrator isn't stable enough for testing. if you have a sine generator or a decent sound card program you can use output to drive a high speed amplifier (Current feedback). Clip the output with a pair of diodes. The output is pretty square at this point. This somewhat square output is fed to a high speed comparator. I have used an Intersil transistor array, (1) but you could use a high speed comparator from ADI, Linear Tech or Tex Instr) It will give you an extremely nice square wave. Square wave generators like to have their cabling and termination impedances etc. all match up. You might want to buffer the output with another current feedback amplifier. When you get to high speeds you get standing waves on the cables etc. (1) the basic idea is shown on an intersil application note "Measuring Phase". |
#9 | |
One comparator and one opamp should be all you need to make a "data slicer" that will maintain a 50/50 duty cycle with a wide range of input amplitudes from a sine generator. |
#10 |
Easy. A 555 oscillator of arbitrary duty cycle. There are examples in the datasheet. But.... Read on...
Now, to make it exactly 50% duty cycle and have nice sharp rise and fall times, drive a CMOS (not TTL) binary counter, and take the output from the first stage. This will give you half of the oscillator frequency at exactly 50%. Use a pot on the output to adjust level... The 4020 is a possible choice. 74HC or 74AC are even better and will give faster rise/fall times. Use of an easily available comparator, like the LM339, would not be a good choice because the fall time will be fast, the rise time will be slow due to the open collector output. The 555 has the same problem, but the counter on the output makes it go away. There are comparators available that have a push-pull output, but the solution I mention will work like a charm. Good luck, John |
| Sine wave - Square & Triangle wave generator using Transistors / OP-Amps | lineup | Solid State | 20 | 9th October 2006 12:15 AM |
| square wave gen needed | sss | Solid State | 21 | 30th December 2004 05:47 PM |
| Microphone turns triangle wave into square wave? | Circlotron | Analogue Source | 18 | 25th January 2003 06:44 AM |
| Page generated in 0.12779 seconds (71.10% PHP - 28.90% MySQL) with 11 queries |
