Square Wave needed
Square Wave needed
Old 28th November 2008, 06:27 AM   #21
Mooly's Avatar
Square Wave needed
Loads of possibilities really. Can be as simple or as sophisticated as you want.
Old 28th November 2008, 07:03 AM   #22
redrabbit is offline redrabbit  Isle of Man
redrabbit's Avatar
I built the Sine-to-Square circuit that jgedde drew/posted above.
Works well too. Possibly better in that it has "flatter" tops. The "comparator" version had a touch of a slope (but may do better if I tweaked some component values).
I have not measured output current drive, or bandwidth yet...gotta work tomorrow.zzzzzz
No need to show waveforms...imagine nice squares.
(both were unaffected by my fluorescent work lamp.)
=RR=
Old 28th November 2008, 07:04 AM   #23
Mooly's Avatar
Square Wave needed
That looks good
Old 28th November 2008, 12:25 PM   #24
jgedde is offline jgedde  United States
jgedde's Avatar
Originally posted by redrabbit
Alright, I'll try those next.
Did you draw up those tonight ?
Thanks, I appreciate it !!
Yes, I did whip them up. Only took a few minutes. No sweat.
You will get better drive capability by changing the 10k pot to a 1k...
John
Old 28th November 2008, 04:07 PM   #25
redrabbit's Avatar
Originally posted by jgedde
Try this... It uses what you have in stock. Don't forget power and ground on the 4013 (not shown).
John
Replacing the 4013 with the 74HC393, does this look right?
(grounding the unused CLK and the two Master Reset pins ?)
(this stuff is re-peaking my interest to finish my modular synth that's been collecting dust.)
=RR=
Old 28th November 2008, 04:23 PM   #26
Nico Ras is offline Nico Ras  South Africa
Nico Ras's Avatar
maybe look at ICL8038 function generator chip by intersil.
Old 28th November 2008, 04:58 PM   #27
PMA is offline PMA  Europe
PMA's Avatar
MAX038 is fine. I get about 10ns rise time.
Old 28th November 2008, 05:21 PM   #28
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
Square Wave needed
Take a look at the 74HC4046 (or similar variants) phase-locked loop chips. They make a very nice, very square, 50% duty cycle, frequency adjustable stand-alone square wave generator at trivial cost (under a buck) and very little effort.
Ignore all the "phase comparators" and just use the Voltage Controlled Oscillator (VCO) portion of the chip. Selecting a few resistors (make R2 a pot to make it variable over a huge range) and a capacitor is about all you need. Couldn't get much simpler, and you can even control the frequency by a DC voltage if you want. Only weak point is not the best jitter so don't use it to clock your DAC.
If you use the 74HC, -HCT, or -LV types you'll be limited to ~5V P-P (though you can go to tens of MHz, should you want). If you don't want to fool with power supplies and need under a few 100kHz, get a CD4046 (or other metal gate version) and power it from a 9V battery (it can run from up to 15V).
Just go to digikey, and search under "4046". You can download the data sheet there, too.
Old 28th November 2008, 08:23 PM   #29
jgedde's Avatar
Yup. Looks right...
John
Old 30th November 2008, 09:47 PM   #30
redrabbit's Avatar
Put one in a Pomona box, with a +5v regulator, and a 9v battery.
Pics:
http://i5.photobucket.com/albums/y17...t/DSCN3562.jpg
http://i5.photobucket.com/albums/y17...t/DSCN3565.jpg
Works good.
There is a very faint skinny overshoot at the leading and trailing edge of the square...don't know if that matters.
=RR=
Square Wave neededHide this!Advertise here!
Sine wave - Square & Triangle wave generator using Transistors / OP-Amps lineup Solid State 20 9th October 2006 12:15 AM
square wave gen needed sss Solid State 21 30th December 2004 05:47 PM
Microphone turns triangle wave into square wave? Circlotron Analogue Source 18 25th January 2003 06:44 AM
