OK, I know this has been covered again and again. I have read threads regarding this subject many times over. Nonetheless, I need to make sure I have a firm grasp of this subject before I continue experimenting.
I see two fundamental problems with this topology. I need the gurus to tell me if I've got it. 1) There will likely be a "balance" issue between complementary halves of the input stage. A circuit needs to be included to keep them balanced. If not included, I would anticipate one half riding the rail and the other doing all the work. I'm not sure I understand why this isn't a problem with a no current mirrors topology. I'm assuming the current mirrors raise the OL gain causing this to occur. 2) Using a Slone style straight push-pull VAS without a current source won't work because the VAS idle current is completely undefined. Yes? Thanks, John Gedde |
#2 |
I'm certainly not a guru, but I do remember seeing something somewhere that a complimentary input shouldn't use current mirrors.
I might be (probably am) wrong though. |
#3 | |
Another issue of concern with complementary input pairs has to do with transconductance matching. This is a bigger concern with JFETs, where the P-channel and N-channel pairs may not have the same transconductance at the same operating current. Mismatched transconductances can cause increased distortion. Cheers, Bob |
#4 |
Thanks Bob. You certainly qualify as a guru!
I'm not sure what you mean about the "output" of the mirror. You mean the "load terminal"? I would expect your suggestion to mean the tied bases of the mirror transistors. In any case, how about this? Thanks! John |
#5 |
Sorry, the non-guru again with a question: What is gained? Other than cost and complexity? That is an audio amp isn't it? |
#6 |
Hi
I thought we covered this already? ![]() My new amp design - the Overkill 180 http://www.diyaudio.com/forums/showt...51#post1413451 BTW, how did the OK180 work out? Cheers, Glen |
#7 |
Good question. A question to which I don't have a convincing answer. It is an audio amp.
Because it's there?. The challenge to get the hypercomplex to work? An obsession with measurements? Good old fashioned psychosis? Perhaps all of the above.... I design "out there" electronics for a living in an industry where better is not always the enemy of good enough. $1200 MOSFETs, $200 2N2222As, $400 LM139's and $6000 FPGAs are routine. The design always must outperform specification even when operating under "outside nominal" conditions. On the other hand, cutting edge components are shunned as not having "heritage." The trick is to use old technology to achieve bigger, better, and faster goals. Gentlemen, we have the technology... One can never have too much money, a lady too pretty, too much horsepower, or low enough distortion... John |
#8 | |
As you can clearly see, your Kleinschmidt 12 was an inspiration. The OK180 is still an elusive goal unfortunately. You're looking at "son of OK180." I'd love to hear more about the K12. How did it sound? Did it perform as well as you expected or hoped? How's that Land Rover coming along? I see you've changed your avatar... Where's Rachel? Cheers, John |
#9 |
maybe my simmed "solution" will help you see if you've understood the issue:
"optoisolator VAS bias for Comp Diff?" optoisolator VAS bias for Comp Diff? also its hard to tell which thread by the default link #, have you seen: "Unstable VAS current in amp from Slone book" optoisolator VAS bias for Comp Diff? |
#10 |
Now that's clever! I hadn't seen that before...
The second link was the same as the first. It seems when I search for something I only get results that aren't in the archive... Thanks, john |
| How critical is matching PNP/NPN in complementary stages? | nelsonvandal | Solid State | 29 | 20th January 2009 08:36 PM |
| Q on PP & current mirrors | JoshK | Tubes / Valves | 13 | 26th March 2007 05:16 PM |
| Current mirrors driving FETs | Kevinbd | Solid State | 23 | 1st December 2006 12:50 AM |
| Current Mirrors and first post here | vynuhl.addict | Solid State | 6 | 16th November 2006 08:43 PM |
| BCV61/62 monolithic current mirrors | Mr Evil | Parts | 0 | 23rd February 2005 02:45 PM |
| Page generated in 0.15947 seconds (68.73% PHP - 31.27% MySQL) with 11 queries |
