hi folks,
well ive got the above amp which i have repaired a few times. however i'ts now popped one of the o/p trannys, they are craftily labelled f15n/f15p. obviously these are mf's own codes, a habit they are fond of so they can rip you off when you need replacements. there's a total of 4 per channel. i've no idea if they are mosfet or bipolar. circuit consists of (input to output ) - 5534 and 5532 , then x2 of each mps a92/a42 (which ive changed a few times), followed by 2sd649/669 pair then the big TO3 f15n/f15p pairs. there is a bias pot too. amp always sounded good but is terribly designed from an engineering point. originally had x4 50V 10000uf smoothing caps, running at , u guessed it, over 50v (53ish). changed them for 63v while ago. i actually wrote to MF 1st time those caps dried out, pointing out the problem. Engineering director wrote back claiming the caps were rated at +10% so 55v . pah! the cheek of it. also the mpsa92/42's literally cook, along with two 1/4 1k0 metal film resistors which should def have been 1/2 watt. anyway, im flat broke at the minute and need to revive this beast. if anyone can help with any info i'd be extremely grateful. many thanks raymond |
#2 |
post a picture of amp inside , so we can compare it with some schematics we have ......
("we" - any of us )
my Papa is smarter than your Nelson ! tnx to |
#3 |
god damn photo too big, will resize at work tommorow and pst then.! thanks
#4 |
ok not so clear due to the 100k restriction .....here u go
#5 |
another
#6 |
send few full res pics to >choky@neobee.net<
try at least to measure one output transistor - on good channel - is it bjt , with simple diode test on DVM
#7 |
hi , i will send you some full res images when i get home later, thanks for the interest greatly appreciated.
will measure one tonight , one channel definately ok . |
#8 |
ok i sent you some pics :-)
#9 |
Magneto the Gravity Man
Remarked Exicon Lateral Mosfets
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#10 |
any numbers andy? thanks a lot
| Musical Fidelity P170 Power Amp | maf_au | Solid State | 66 | 8th December 2011 08:35 PM |
| Musical Fidelity A100X Power supply | PTH | Solid State | 6 | 19th February 2006 09:49 PM |
| Musical Fidelity Elektra E100/E300 | planet10 | Solid State | 2 | 15th May 2005 07:12 AM |
| Page generated in 0.12369 seconds (71.51% PHP - 28.49% MySQL) with 11 queries |
