Old 19th November 2008, 03:11 PM   #1
cs is offline cs  United Kingdom
Default Bias chain current for SAP16
The datasheet for the SAP16 temperature compensated darlington transistors recommends a bias current of 2.5mA down the diode biasing chain. In a practical power amp, this current would also flow through the VAS stage. But 2.5mA is quite low for the VAS, and I would normally use 2 or 3 times that.
Has anyone tried the SAP devices at higher bias chain currents, and if so, does the temperature compensation still work OK ?
Chris.
Old 19th November 2008, 03:18 PM   #2
AndrewT is online now AndrewT  Scotland
the bias chain of diodes is ~ 5diodes + a variable resistor.
What voltage do you expect across this combination? Maybe 2.5V?
what parallel resistor would be required to pass the excess current through the VAS? Maybe 470r.
Leave a couple of extra pads to add one or two parallel resistors to trim the diode current once you get it running.
regards Andrew T.
Old 19th November 2008, 03:21 PM   #3
Hi Andrew,
Yes, that did occur to me, although I was concerned that the compensation effectiveness would be reduced.
Chris.
bias voltage vs bias current woodturner-fran Tubes / Valves 3 24th February 2007 11:24 PM
Bias and max current for my 7591 AB amp... mr mojo Tubes / Valves 14 6th January 2006 02:50 AM
LTP bias current cunningham Solid State 2 12th January 2005 08:39 PM
Bias current peter5 Solid State 6 13th January 2004 04:39 PM
BOZ Bias Current gema Pass Labs 2 20th February 2002 07:28 PM
Page generated in 0.08769 seconds (74.62% PHP - 25.38% MySQL) with 10 queries
