Old 19th November 2008, 02:26 PM   #1
bogdan_borko's Avatar
Default 2SC3423/2SA1360 models?
Does anyone have spice models for 2SC3423/2SA1360?
Old 19th November 2008, 04:25 PM   #2
homemodder's Avatar
.MODEL 2SC3423 NPN(IS=9.98627F BF=2K NF=967.67M VAF=100 IKF=49.6929M ISE=1.04163F NE=1.07574 BR=601.257M IKR=462.798U ISC=32.904P RC=899.97M
CJE=2P MJE=500M CJC=6.42174P VJC=749.999M MJC=499.509M TF=713.346P XTF=500M VTF=10 ITF=9.9976M TR=10N)
.MODEL 2SA1360 PNP(IS=10F BF=134.853 VAF=100 IKF=109.96M ISE=221.874F NE=1.66575 BR=10 IKR=880.176M ISC=187.58P NC=1.90472 RE=1 RC=15.5104
+ CJE=2P MJE=500M CJC=6.24728P VJC=692.028M MJC=340.013M TF=1.08385N XTF=16.9293 VTF=9.36211 ITF=670.025M TR=10N)
Old 19th November 2008, 06:16 PM   #3
thanks!
Old 19th November 2008, 06:59 PM   #4
EDDELARUE's Avatar
Send a message via MSN to EDDELARUE Send a message via Skype™ to EDDELARUE
Is that acurate models? Where is it from (Orcad , Intusoft , Multisim ) ?
-Ed
Old 20th November 2008, 08:51 AM   #5
homemodder's Avatar
No spice models that I have seen can be taken as accurate, Andyc a member here has significantly improved some output transistor models to be quite accurate. The rest well....... Its very time consuming to do just one single model and we can be thankful he looked at some, as most are terrible.
The models I gave were placed in this forum. Thats a very good transistor, sims will display superior performance compared to other transistors. However, whether accurate youll have to test them and run some hfe|IC and IC vbe sims and compare to datasheets.
BTW in some of those spice programs I have found the most unaccurate models, you cannot take for granted that those companies did the modelling, they only supply what the manufacturers give and whats out there on the web. One sometimes find 7 different models for a single transistor, which one is the most accurate ???? Only by testing one can tell. The japanese manufacturers dont even supply models so whats out there was most probably done by privates.
Old 20th November 2008, 11:47 AM   #6
EDDELARUE's Avatar
Ok!
Thanks for attention.
-Ed
Where to find original Toshiba 2SC3423 in Europe? supernet Everything Else 3 13th July 2008 09:29 PM
help with models. bogdan_borko Solid State 7 11th November 2006 02:19 PM
2sc3423 spice model sunrise Solid State 9 20th June 2006 07:20 PM
mje models? bogdan_borko Solid State 2 29th May 2006 11:37 PM
transistor models ghammond Parts 0 26th May 2006 02:28 AM
Page generated in 0.09624 seconds (72.45% PHP - 27.55% MySQL) with 10 queries
