Is this type of protection detrimental to sound quality? I would like to employ it in a project to make it as "dummy" proof as possible.
#3 |
if that's good enough for many opamps, then why should be a problem with a power amp?
What diode characteristics are required to give good audio performance? Extra diodes to prevent the input signal, in common mode, going above a limiting window voltage might be even better protection. There are a few schematics on this Forum showing this.
regards Andrew T. |
#4 |
It should not really affect the sound, but isn't really needed too unless you want to severly overdrive the circuit, like having an input voltage around 7-10V or so, so that transistor b-e diode must work at zener range.
Such diodes are used in op-amps which is good, because an op-amp does not have to work as a linear device with negative feedback. Adam |
#5 | |
This is the same as an opamp and controlled by the same rules. The output tries to ensure that the difference in the two input signals is zero. This is usually <10mV for all audio signals. The protection is there for non-audio signals and/or faults.
regards Andrew T. |
#6 | |
Hi, Putting 2 or more in series would increase the input threshold, no? I want to guard against "hot swapping" of input cables and other silly things that can take place when my back is turned. |
#7 |
as darkfenriz tells
- they are only needed in very special situations - for most normal audio amplifiers you can do as I do = no diodes - for commercially sold op-amps, they never know what user will try them for - so is more a very worst case thing for avoid customer conflicts, just in case
lineup |
#8 |
You should rather use reverse biased, connected to zener defined voltage e.g. This shown here is no good.
#9 | |
only detrimental to purists. it won't hurt. go for it
Just because you can't hear it doesn't mean no one can. |
#10 |
surroundings....your neighborhood.... magnetic field from RF will be detected and can overdrive your input transistor... input may turn near saturation...noises will be captured and may pass to second stage.... you may read AC voltage there with 1 volt or more... the transistor will show saturating voltage from colector to emitter...sometimes happens. But this is very rare to happens...only when you have a Radio Amateur with a powerfull station near your home...or AM/FM broadcasting.... Television Stations or Police Radio Transceivers, Radars and those equipments that use Radio Frequency (cell phones are too much weak to bother...you have to touch the input diodes with your cell phone aerial (antenna) to obtain interferences. Cell phones use to send signal from time to time to the nearest reception station ... this signal can be heard into the amplifier when using high speed transistors and protective diodes into the input. But i cannot imagine the idiot will put the cell phone over the power amplifier board inside the enclosure...hard to imagine the crazy guy doing that. Well.... they have capacitances.... diodes have inductances and resistances.... of course may tune something. So...no real problems.... only rarities will bother the one is using diodes..... just in case... i have never used... and just in case will never use them. Carlos |
| psu protection diodes - specified volatge | redrabbit | Power Supplies | 6 | 4th August 2007 02:47 PM |
| mosfet amp protection diodes | sakis | Solid State | 41 | 16th May 2007 10:54 AM |
| protection diodes in LM317 circuits | jarthel | Parts | 2 | 14th September 2006 10:28 PM |
| Page generated in 0.11475 seconds (74.05% PHP - 25.95% MySQL) with 11 queries |
