Current Mirror: The V-mirror
Old 19th November 2008, 12:47 PM   #1
rtarbell is offline rtarbell  United States
Default Current Mirror: The V-mirror
I saw this specific mirror referred to in the related "Current Mirror Discussion" thread. I had a question about it, but I didn't want to thread jack.
This mirror has been referred to as the "V-mirror", or the "Gilbert Current Mirror".
--> If we are using an opamp to equalize the drain voltages between the two transistors, isn't there a potential for positive feedback (depending upon the load connected to the output side of the current mirror)? I believe that the path from the output of the opamp to its inverting terminal, and the path from its output to its negative terminal, *could* be the same path.
If I remember my nuts and bolts properly, I think that an opamp must have more negative feedback than positive feedback if it is to act stable (instead of a switch like a schmidt trigger). In this schematic, there is the potential for more positive feedback than negative feedback. Am I missing something?
Old 19th November 2008, 02:27 PM   #2
darkfenriz is offline darkfenriz  Poland
darkfenriz's Avatar
It assumes infinite impedance of the current source and finite and positive impedance at the output, so there is more nagative feedback then positive.
In theory it could work, but will be very sensitive to capacitive loading (stability!) and to any overdrive situations.
Current Mirror: The V-mirrorHide this!Advertise here!
Current Mirror Discussion AKSA Solid State 348 24th March 2017 09:21 AM
Current mirror for the aleph? 3nity Pass Labs 11 8th August 2013 07:23 AM
no current mirror, current mirror, cascoded current mirror, bjt or jfet VAS? maxpou Solid State 31 17th June 2008 04:31 PM
A special current mirror pjacobi Solid State 13 16th June 2008 04:16 PM
Current mirror abzug Solid State 7 1st January 2008 07:03 PM
Copyright ©1999-2017 diyAudio
