hi guys
after a bit of help, im looking for a phono stage schematic (or board) with a modified RIAA curve (ie more bass) or adjustable turnover /rolloff found a schematic a while ago but just cant seem to track it down now.. i can assemble boards from diagrams but cant design anything its just for playing standard RIAA records, just im not happy with the overall "sound" of every phono stage ive tried, so id like something adjustable, or something that deviates from the riaa curve thanks! |
#2 |
How about just using a tone control ( parametric equaliser or just multi band equaliser ? ) after the phono stage .
A good phono stage should sound good and not require any alterations to it's turn over frequencies if : 1. The phono preamp itself is good 2. The cartridge is good ( including the stylus !) 3. The tone arm is good 4. The turntable mat is good 5. The turntable itself is good 6. The turntable chassis is well isolated 7. The coupling RCA cable set is good 8. The power amp is good and 9. The speakers are good AND 10. A well cut vinyl album is used ! That gives you a whole range of areas to work on to improve what you hear.
AM |
#3 |
Bass Booster
to be used to attach AFTER the phono RIAA. You have a rotary switch ( use 4 postions of one 6 pole ) - Pos 5 = Flat +12dB gain, Green curve - Pos 4 = High Bass boost, Red Curve - Pos 3 = Low Bass boost, Purple curve - Pos 2 = Flat 0dB, Blue curve My own fresh custom designed schematic, comes in next post.
lineup |
#4 |
Power supply can be two 9 Volt Battery
or 2 x 12 VDC IC regulated LM7812 and LM7912, for example Enjoy Lineup
lineup |
#5 | |
of course I can try do circuit for this, too
lineup |
#6 |
Her's a couple of links describing a really good RIAA pre-amp with a selectable slight boost of the bass. I use it myself since a few months and it makes all the difference in listening to vinyl! Unfortunately all the doc is ion swedish, since it was developed and published by LTS, the Swedish Sound Association.
The schematics: http://user.faktiskt.se/naqref/LTS_riaa/riadia.pdf It's C5 that you short circuit to gain a couple of dB more bass. Partslist: http://www.naqref.com/pdf/Komponentl...TS-RIAA_07.pdf |
#7 | |
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#8 |
try this
it works!!!!½!!!!!!!!!!! http://user.faktiskt.se/naqref/LTS_riaa/ always is funny to be allowed to peak into other's peoples folders
lineup |
#9 |
Still got;
You don't have permission to access /naqref/LTS_riaa/ on this server.
| Can someone tell me what this adjustable pot is for ? | WBFAir | Subwoofers | 4 | 31st March 2007 02:32 AM |
| adjustable XO / amps ? | jimbo1968 | Chip Amps | 23 | 15th May 2005 07:51 AM |
| adjustable crossover | rv1890 | Multi-Way | 2 | 11th January 2005 10:03 PM |
| Need adjustable LPF for sub... | JojoD818 | Solid State | 5 | 7th October 2003 06:55 PM |
| adjustable xover | Austin | Subwoofers | 6 | 23rd April 2002 09:21 PM |
| Page generated in 0.13394 seconds (71.93% PHP - 28.07% MySQL) with 11 queries |
