The Frugalamp by OS
The Frugalamp by OS
Old 19th January 2009, 08:17 PM   #691
keantoken is offline keantoken  United States
keantoken's Avatar
Originally posted by AndrewT
Hi Kean,
could you substitute a red LED for the twin diodes?
I hear that a red LED has a similar temp co to a BJT.
I would like to see both the ripple and the temp variations.
The ripple is indeed less.
This is the tempco simulation. This doesn't show in the graph, but the current through the LED CCS actually rises as it gets warmer, while the others get lower. I hope I did this right. The LED is biased at around 10mA.
I used a red LED model I found via Google, not sure how accurate it is.
- keantoken
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 19th January 2009, 08:20 PM   #692
keantoken's Avatar
And here is the ripple.
- keantoken
Old 19th January 2009, 08:32 PM   #693
keantoken's Avatar
I'll assume I've got the right to double post now since I'm the man with the sim.
I was googling and found this:
For protecting mosfets (zener as a shunt across gate and source) I have used with good success a reverse biased base-emitter junction of generic BC550 or BC560. Capacitance is low and the zener voltage is quite the same across different devices.
Gerhard
Has anyone tried this? I don't think a simulator will do this right. I think I've read this in an application note or something also.
Perhaps mr. Christer or someone can set us up some good measurements.
- keantoken
Old 19th January 2009, 08:42 PM   #694
ostripper is offline ostripper  United States
ostripper's Avatar
I did the diode vs. LED test and the LED wins..
(see attachment)
PSRR wise
In an actual circuit with the cap (like the FA2 I'm listening to)
the LED beats the diodes by 10 more db(most likely the cap)
and has almost no thermal drift. BUT "strait up' with no
decoupling, the led beats the diodes by just 1 DB.
Next post I will use the decoupling techniques from the nakamichi
620 which compensates the current source differently.
OS
Old 19th January 2009, 09:18 PM   #695
keantoken's Avatar
Which LED model are you using?
- keantoken
Old 19th January 2009, 09:52 PM   #696
ostripper's Avatar
The QTLP690 fairchild 1.8V red led.
In the whole scheme of things
the PSRR/ripple factor of the diamond CCS's really only
help to stabilize the
biasing of the OP stage (vbias). The whole diamond buffer
is corrected by NFB so the current sources are just overkill.
In the Krill, they are using a dual voltage supply even with
current sources ,but the Krill does not wrap the current stage
with the NFB loop.
Attached below is the (I think) close to final plots that I
really like. (perfect gain to 100k and 100db phase margin).
The diamond seems to extend the bandwidth of any
standard amp by some degree and allows for a unloaded, low
current VAS as a bonus..
OS
Old 20th January 2009, 09:55 AM   #697
nelsonvandal is offline nelsonvandal  Sweden
nelsonvandal's Avatar
OS
DB's do sound good. I find them better than simple EF's. If you listen to an open loop DB you'll find they sound very transparent.
Old 20th January 2009, 06:02 PM   #698
Steve Dunlap is offline Steve Dunlap  United States
Steve Dunlap's Avatar
Hi ostripper. I'm trying to catch up here after a couple of days without Internet service.
Run open loop, as I do, my amps have a very low output impedance and excellent speaker control. I prefer the sound without feedback so that is how I build. Distortion specs are also very good run open loop and there is no chance for the stage to become unstable or oscillate. As an added bonus, if the output to the speaker gets shorted you don't loose the feedback and go OLG.
I never really worried about what would happen if the compensation (diode string in my case) failed. If it shorted it would simply reduce bias. This would affect the sound some, but do no real damage. If it opened it will blow the line fuse. With less than 0.1mA of current the diodes should never fail. It is always possible for a connection to break however, so I will add a resistor in parallel with the whole string to set a maximum bias in this event.
Thanks for pointing out this potential problem.
I am attaching a simulation result showing the output stage only, run open loop with a 20V input. As you can see it shows a 3dB down point at only 3 MegHz. A test on a real unit only gave about 1.5 MegHz. Still, I think that is good enough for audio.
Old 20th January 2009, 07:29 PM   #699
ostripper's Avatar
I didn't mean to point out a problem , but I don't want to be
a contributer to burning amps .
I've tried both including or omitting the diamond current
stage in the NFB loop with little effect other than ,with the
isolated current stage, no change with load. (As you pointed out.)
Another interesting note is that by degenerating the darlington
(470r - 2.2k) like a standard EF type 2, "tames" a little
bump at 5MHz (I think that is where this thing "likes" to oscillate)
and sets the phase margin.
I already did the carlos thing and no fire , so I know it works. I tested what would happen if my vbias died and it
is the safest I could imagine.. just 300ma (severely overbiased).
Idiot proof, much better than a typical amp. A total short at
the output would just burn the basestopper resistors.
It seems DIYaudio has gone "krill crazy" these days, even
carlos (no trashbin or buckshot) likes it, 3 seperate diamond
topology threads... you started it all ,steve, thanks!
BTW..., yours(krill) is most like the Nakamitchi 620, except they use an EF'ed diamond which is the thermal compensation .
(attached)
OS
Old 20th January 2009, 07:44 PM   #700
ostripper's Avatar
This is what I have so far, I can't seem to find any problems
with this. (comments welcome)
OS
The Frugalamp by OSHide this!Advertise here!
