Old 17th November 2008, 12:50 AM   #1
tomat is offline tomat  Indonesia
Default help... diode on emitter
anyone can give me a little bit explanation,what is the purpose of diode on emitter? it install on output transistor ,from emitter to ground & paralel with 1 ohm/0,5watt resistor.
i see this in power amplifier
thanks
Old 17th November 2008, 01:03 AM   #2
lineup is offline lineup  Sweden
lineup's Avatar
sounds strange
we need more info
lineup
Old 17th November 2008, 03:13 AM   #3
Send a message via Yahoo to audiomachines
yap, I've been wondering about this too, I seen this one on a crate fender guitar amp I have repaired, output transistors where darlington type TIP 142/147. stabilization? wired like an Re resistor, or "flavor" for that rectified sound? definitely not a baker clamp.
Best regards,
audiomachines
Old 17th November 2008, 03:17 AM   #4
burbeck is offline burbeck  United Kingdom
hi
maby a 'Baxandall diode'
regards
bob
Old 17th November 2008, 05:01 AM   #5
is this also called feed forward diodes?
diode bridge - 10000uF cap - diode tube - small cap - HV+ engels Tubes / Valves 5 29th January 2008 10:16 PM
hybrid power supply: diode bridge into diode tube engels Tubes / Valves 8 24th September 2007 09:18 AM
ASR Shafer Emitter 1 and 2 sparkle Solid State 43 11th May 2007 08:06 AM
Emitter Resistors hawkfeather Solid State 15 29th January 2006 05:28 AM
Emitter Resistors EchoWars Solid State 16 16th July 2005 10:47 PM
Page generated in 0.08121 seconds (72.14% PHP - 27.86% MySQL) with 10 queries
