Old 23rd November 2010, 01:27 PM   #81
bleep42 is offline bleep42
Default Aura VA100 Upgrade
Hi Matthieu,
Thanks for your reply. I am about to order an LME49720HA dual high quality op-amp, and will be upgrading some of the power capacitors too, what made the biggest difference in your opinion?.
Kevin.
Old 24th November 2010, 12:15 AM   #82
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Good to know you are still there
Old 24th November 2010, 07:56 AM   #83
Malefoda is offline Malefoda  France
Malefoda's Avatar
Send a message via MSN to Malefoda
Mine was faulty, when fixed sounded dull.
After that the RIFA PEH169 brought some life back.
And then the caps at the op-amp changed the sound more than the op amp itslef, Rubycon ZA get clear and detailled, BlackGates warmth. Room to play and choose there
Seems you can look at rectifiers there, I did not but worth it ... I guess.
Hi Ricardo, yep but soon will have my Internet cut :'(
And later back
QED T260, Thorens TD-318 & Ortofon Super OM 20, Teac VRDS-10, Buffalo II & NTD1, UCD400, JBL 4313B: music!
Old 29th December 2011, 02:38 PM   #84
Gregje is offline Gregje  United Kingdom
Hi Guys,
I have a faulty VA80se (one channel disappearing sometimes). I have seen in this threat that some of you guys have the service manual (well for a VA100, but it should do I guess). Do you mind sharing it?
Send me a pm.
Many thanks
Greg
Old 6th May 2012, 08:52 PM   #85
Tutundziev is offline Tutundziev
i didn't want to start a new thread cause i'm a new member of the forum, i have the aura evolution 100 VA II, and couple of months now, it somehow lost the bass, now fully but it's lower ( i know that this sounds funny ) tried with other speakers and the same results, a friend of mine told me that it can't just be just the amp maybe it has something to do with the cd player ( don't know how i know that this sounds funny too ), and also it has some weird sound while using the volume knob don't know what was the word for that, any help will be apprecieted
p.s. sorry for my bad english
Old 13th May 2012, 09:14 PM   #86
My problems disappeared when I resoldered almost all solder points inside the amp. The brumming problem disappeared when I resoldered the PSU board. Missing channel was more tricky. At first I restricted myself the preamp circuit ( as I still could hear some static floor noise with the amp on and sticking my ear to the spreaker of the channel that has gone; I thought the power amp section was still ok). It did not help, so I resoldered every joint. I am using the amp for a few months without any problems.
Old 17th October 2012, 11:45 PM   #87
cirrusminor69 is offline cirrusminor69  Portugal
Default Aura Evolution VA-100
HI,
I have the same amp, but its not the MKII model.
I whant to make a recap but i dont have the schematic and i cant find it anywhere.
I need the schematic (only) to set up the bias.
Can somebody help me please! Thanks.
Old 5th February 2014, 07:16 PM   #88
Question Aura Evolution 100
Hello.
how can you adjust the bias on this amp?
Old 3rd March 2014, 08:21 PM   #89
smitsch is offline smitsch  Switzerland
important bias info:
1. connect the AC- ampmeter to the AC powercord, connect 8Ohm loads to the LS outs
2. set the bias values to min. : "RV22 (fully ClockWise) & RV122 (fully anti ClockWise)"
- take care on writen words: my bias pots have other number (RV 1 & 2) in EVO2 - unsure if given direction to minimum is correct for every pcb Revision...
4. with bias on minimal, and no Signal, idle current should be:
24mA for 220/240Vac
48mA for 110VAC
50mA for 100VAC
5. Now open the bias trimmer:
+48mA/ch for 240VAC
+50mA/ch for 220VAC
+100mA/ch for 110VAC
+110mA/ch for 100VAC
6. do the same for channel 2
in the end, the currents are 1x idle & 2x Bias , just add the values for both channels
i would suggest to replace the black omron Relais, this seems to be underrated. I went for the yellow panasonic DS2Y-S-12 ( 250 V/AC Max. 60 W/62,5 VA)
SnPb, thd, pcb, daw, pa, foh, diy, maybe, why?
Old 4th March 2014, 02:31 PM   #90
Tanks
Aura Va100 Evoluton Ii ANALOG GUY Solid State 35 12th September 2017 12:56 PM
evolution algorithm Jamh Everything Else 0 8th June 2009 06:04 PM
Aura CDP Clean up & upgrade Malefoda Digital Source 39 5th April 2009 10:40 AM
Evolution MK-7 midi keyboard em2006 Instruments and Amps 1 12th September 2008 09:55 PM
Evolution board AD1955 fantomas Digital Source 1 30th September 2005 11:03 PM
Copyright ©1999-2017 diyAudio
