Aura Evolution VA100 Clean up & upgrade - Page 2 - diyAudio
Old 17th November 2008, 08:54 AM   #11
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Originally posted by Malefoda
The dead picture from the main post:
Hi
Did you replace the opamps by some LM 4562 ?
RC
Old 17th November 2008, 09:30 AM   #12
Malefoda's Avatar
Send a message via MSN to Malefoda
Ok Andy,
I'll stick to opamp then, and no Ricardo not yet but I'll fit my last LM4562 in soon. Some good caps to supply them? BlackGate as always?
QED T260, Thorens TD-318 & Ortofon Super OM 20, Teac VRDS-10, TDA1387, UCD400, JBL 4313B: music!
Old 17th November 2008, 05:18 PM   #13
Malefoda's Avatar
Damn I've mixed the thread about the CDP and this one...
Andy's pics about the origin of the B & W's Aura stuff:
Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
Old 17th November 2008, 05:31 PM   #14
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Eek, ITL was B&W owned ?
It doesn't count how one deals with winning, but how to handle a loss ( DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 17th November 2008, 05:41 PM   #15
aandy is offline aandy  United Kingdom
Yes B and W brought out ITL
You have a proper amp then?
Old 17th November 2008, 08:40 PM   #16
Malefoda's Avatar
Cross threads...
Maybe I can get rid of the Muse and fit them in the amp for the same job, why havin' 2 times these boring caps?! Once in amp is enough no? Or spend few euros for a real cap there, a film cap like an ClarityCap or such?... I'm asking that again in the amp thread.
Amp has 2x Rubycon NA non polar just after the potentiometer...
Also don't know what to do for those little thingy of Elgen 220F/35V, seems to supply the opamp.
The 15 year old BHC should be changed or not?
I'll take pics of the pcb when I'll fit the LM4562.
Matthieu
Old 18th November 2008, 05:56 PM   #17
nhinstruments
RCruz's Avatar
Cross threads...
Hi Matthieu
I replaced the stock smoothing caps in my 30 years old power amp with some 15000uF Mundorf and the result was very good. (Much more speed and control..... better high freq detail).
On the opamp you can also use Rubycon ZA instead of BG.
Ricardo
RC
Old 18th November 2008, 06:22 PM   #18
Malefoda's Avatar
Good Ricardo,
I'll have to take the PCB appart and check under what does what before choose. I may fit the LM4562 and new cap if any at the same time.
Right now the problem is to find some cap quite not high to keep the slim lid closed clean.
I also want to keep the sound warm ans soft.
Right now the same BHC ALC10 but 6800/63 instead of 4700/63 will fit, they're 35mm high both and 35mm of diameter for the 6800 and 30mm for the 4700. And capacity is more, don't know if it can do bad or good... or maybe same capacity but bigger for better specs?
I'll be back with pics.
Old 18th November 2008, 09:23 PM   #19
nhinstruments
RCruz's Avatar
The bigger the better as long as you do not go over 22000uF... after that you might need to bypass the smoothers.
RC
Old 19th November 2008, 12:45 PM   #20
Malefoda's Avatar
Here we go for latest news and questions...
As you will see on pics I've removed the second outputs, it's a simple Y connection so it's useless. Maybe was acting a bit as an antenna... LM4562 is in, 0.47 MKS Wima between 4&8.
On a pic you will see both BHC caps had contact with the aluminium radiator frame (one transistor also... moved it up...), it's burn on both pins on one cap and on one pin the other. Are they degraded? It's working fine but has been given to me as sometimes making noises on one channel. Maybe this contact
If really needed or a big upgrade, what if I go for the BHC (the only ones fitting well the lid as far as i've found) 6800/63 instead of the 4700/63? I've read (my Acram thread) that it can harm the sound in some ways, is it true? Also I've seen all other guys modded this jumped to 6800 ans sticked to it so I think in that case it' all good.
Where to buy BHC ALC10 caps 6800/63 online? Can't find them at all :'(
The ALPS pot feeds 2x MKT 0.470F, I think I'll have good gain by fitting something more serious as a ClarityCap or such, bigger capacity like few F? Size will be a concern here again. I'll go for multiple brand of caps maybe PX and SA.
The small caps non polar (were Rubycon NA 100/16) has been changed for the removed Muse 100/16 from the CDP, they're far bigger.
Still have the Elgen 220/35, what do you advise there?
Any tips to screw back the transistors to radiator? May I remove the kind of sheet between and put some Arctic Silver III (got some, mac overclocker inside) ?
There are the pics, last one is flipped in order to let you match stuff and circuit. In fact it dusturbs me more than makes me easier... Hope it's ok for you!
Thanks for helping fellas!
Matthieu
Aura Va100 Evoluton Ii ANALOG GUY Solid State 34 6th January 2016 10:10 PM
evolution algorithm Jamh Everything Else 0 8th June 2009 05:04 PM
Aura CDP Clean up & upgrade Malefoda Digital Source 39 5th April 2009 09:40 AM
Evolution MK-7 midi keyboard em2006 Instruments and Amps 1 12th September 2008 08:55 PM
Evolution board AD1955 fantomas Digital Source 1 30th September 2005 10:03 PM
Copyright 1999-2017 diyAudio
