#21 |
sorry just read your last post and if the meters read dbu there not the ful scale meters most digital gear comes with. Any source of test signal? Pro gear is designed to run at +4dbm (0VU) nominal signal. If your meters are in dbm(dbu) a music signal should sit between +4 and +8 dbu on the input whitout going over. This should maximize your S/N and still leave enough headroom.
#22 |
sorry again Are you saying your output meters only reach -30dbu??? Then Im confused. I thought your outs were too high and you wanted to pad them? This is too low and maybe your +4 -10 switch affects the outs also, which should get rid of your problem?
#23 | |||
I guess the meters on the dbx are non standard Here's a picture of the unit. http://cachepe.samedaymusic.com/medi...94c11f3ad8.jpg Quote:
#24 |
you are correct about more output, this unit is also EQ ,compressor etc make sure this stuff is all bypassed to start. And your right (sorry just thought of this) this unit is made to work at zero out wich will drive your amps into full power so you need a "volume control" before the dbx, your preamp. lower the input, its 24 bit so it should be OK
#25 |
The DBX doesn't clip until it hits +20dbu acording to the input leds. Unless I'm missing something +10 to +15dbu on peaks is ideal, no? Everything I've read on the subject states that you want to set up your gain so you maximize the resolution of your A/D & D/A converters (without clipping). Most feel that you're even better off using a 6ch volume control after the digital X-overs D/A conversion. Ok, first off don't trust the led's or any analog meter. They are there for a rough estimate of what is going on. The proper way to set up the device is with test gear. Input a signal and adjust to have all pieces clip in the signal chain at the same time. The specifications on this device say 24bit and it should remain 24 bit processing regardless of the level input and or output. The grainey sounding is a result of improper setup. I have used Shure DFR22's in applications and have NOT hit the input hotter than 0db with absolutely no problems. I have used other DBX products and have not hit the input hard and haven't suffered sonically. |
#26 |
and yes do add the T resistor pad on the outputs; 15 db should work
#27 |
Thanks again for all the help guys. I built up a L pad on a breadboard to test things out. My Trends Audio chip amp is unbalanced and running the show from 500-7khz so I figured it'd be a great place to run a test.
Using a 100ohm shunt resister and 5K ohms R1 in series gets me in the ball park volume wise but I think a little less attenuation would be better. I'll buy some more resisters and experiment. As far as impedance matching goes the dbx has an output impedance of 120ohms. I couldn't find the input impedance of the Trends Audio chip amp, but power amps tend to be in the 10-47kohms range, so 5k is a little low So with that in mind my L pad isn't impedance matched. I didn't notice any change in tonality (the side effect of incorrect impedance matching?) but IIRC some of the other pad configurations should provide a better impedance match. As far as sound goes there was a significant improvement in sound over the 500-7k range. More hall/reverberation sound, better separation of voices and a less homogenized sound stage. |
| How do I turn an high current signal into a line level signal?? | sardonx | Tubes / Valves | 8 | 27th August 2005 11:16 AM |
| Any1 no a cct for converting mic to Line level (RCA's) | scottb721 | Analogue Source | 4 | 9th June 2005 08:32 PM |
| Professional to Consumer line level converion and back! | bans25 | Analogue Source | 2 | 2nd April 2005 09:44 PM |
| Professional to consumer line level conversion on PCB | bans25 | Chip Amps | 0 | 31st March 2005 11:44 AM |
| how to bring down line level signal to preamplifier level | deji | Solid State | 15 | 15th April 2004 04:13 PM |
| Page generated in 0.41692 seconds (20.09% PHP - 79.91% MySQL) with 10 queries |
