My first DIY amplifier 20 years a go
Old 24th June 2017, 01:26 AM   #591
gaborbela is offline gaborbela  Canada
Hi
Guys it may sound very stupid but I am tempted to use these Hitachi power device to replace the TIP type of power darlingtos...
Any constructive opinions, comments are welcomed
HTTP 301 This page has been moved
Can these device replace those darlingtons with minimum or no adjustments?
Greetings
Old 24th June 2017, 08:02 AM   #592
R.I.P.
attach the datasheet.
Which post shows the sch?
regards Andrew T.
Old 24th June 2017, 12:06 PM   #593
Hi Andrew
The Hitachi datasheet I posted with my question, to met opens but I add it again with the complementary
I post the TIP147 & 142 so it will be easier to look it up.
http://www.st.com/content/ccc/resour...CD00000914.pdf
The amplifier schematic one page back post 582
The reason I do not post direct I have an old LTspice IV software when I open with that the darlington devices are missing.
You may have something better
My question remain can I use those Hitachi devices to replace the TIP..
Greetings
Old 25th June 2017, 02:36 AM   #594
anatech is offline anatech  Canada
anatech's Avatar
Hi gaborbela,
I can't see the schematic, but you can't replace a darlington transistor with a normal transistor. You would need to adjust your bias circuit to compensate for the different Vbe drop. The other change will be that the Vas sees a greater load variation because the current gain is lower. If they are both darlington types, then the change should be pretty easy. I don't know of any Japanese darlington audio outputs though.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 25th June 2017, 03:00 AM   #595
ashok is offline ashok
ashok's Avatar
The 2SD1559/2SB1079 are Darlingtons from Renesas. It can be used. It is rated 100V 20 Amps ! TIP142/147 is 100V 10 Amps. There is a slight difference in power dissipation but that shouldn't matter here.
AM
My first DIY amplifier 20 years a goHide this!Advertise here!
camelot arthur dac 20 years old inertial Digital Line Level 5 22nd December 2012 09:57 AM
My best sound amplifier of these last 20 years audiodesign Solid State 22 28th August 2011 10:54 PM
new speakers after 20 years sys3 Multi-Way 5 28th May 2006 04:08 AM
Pic: 20 years old wasted on Xmas! Prune Everything Else 5 27th December 2004 10:01 AM
2N3055...supply for 20 years!! Netlist Swap Meet 5 11th June 2003 11:45 PM
