My first DIY amplifier 20 years a go
Old 18th August 2014, 10:34 PM   #561
gaborbela is offline gaborbela  Canada
For coupling caps I do not like large value caps, that would be my correct statement.
If the PS built on a PC board like many commercial amp we have to use what ever need for there.
If you look at my layout you can see if I rotate the capacitors (next to the power transistors) I can use even 2200uFt to.
There is room enough there.
I will see if really necessary to go over 470uF what I think is a decent capacitor for that position.
By the way these is the final layout what I will use at my tests.
The size of the PC board 86 X 82mm
86 wide frame to frame and 82 long.
Greetings
Old 22nd March 2015, 05:26 PM   #562
Bigun is offline Bigun  Canada
Bigun's Avatar
Any progress on this project, the dream should not end yet...
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 22nd March 2015, 07:34 PM   #563
It is not over yet.
I prepared to etch several different amplifier PC boards so that is the reason for the long wait.
Greetings G
Old 23rd March 2015, 01:32 PM   #564
ashok is offline ashok
ashok's Avatar
Hmmm....I went off track around mid 2014 and never got back due to a lot of reasons plus side tracked by some new things that came along......usual rant ..
However I do want to complete my stereo version for which I had even bought the transformer and heat sinks ! I think I will do something this year ! In the meantime the L12-2 amp caught my attention . After many months I bought the boards recently on eBay. Making boards myself is becoming time consuming.
The L12 amp is very nice . Will have to compare that with your amp. Since there are some variations possible I'll pick the one I like best to test. Two important factors will be dc offset stability ( with fluctuating supply voltage ) and dc bias stability.
Cheers.
AM
Old 2nd August 2015, 11:13 AM   #565
Hi
Mosquito simulated the VBE modified version the result he get is very bad.
With these tweak the sim result is (very) good but may be we back to the thermal drift problem.
Who knows
I think I will build these and if there will be problem try to solve it on the actual amplifier.
I waited until now so someone simulate the VBE molded circuit.
Now time to work on the layout and after turn on the soldering station.
Bigun or anyone else who interested please take a look at the latest circuit
Old 4th August 2015, 05:32 PM   #566
Bigun's Avatar
I am happy to see this thread coming alive!
Still, I suggest somebody should run quick Spice sim with "TEMP 30 40" to see how stable is bias of output power devices with temperature. More sophisticated simulation needs control over individual devices of course but it's simple enough to do global test whilst you begin some real soldering!
I like this topology and I have reserved many pairs of Sanken Darlington devices for when time is available !
Perhaps good to add a capacitor across Vbe to ensure good a.c. Behaviour.
Old 5th August 2015, 12:13 AM   #567
Hi
Bigun I agree with the capacitor across to the VBE
Very likely next to the VR2 we will need a resistor, one side it has 2K2 the other side only a 470VR.
At least for test I made the room for the mentioned components
The resistor marked as a J jumper the capacitor not marked but is there in the layout
Greetings
File Type: jpg -my-first-diy-amplifier-20 y. moded by Mosquito +1.JPG (173.1 KB, 351 views)
Old 5th August 2015, 12:35 AM   #568
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
One of my first builds was a Maplin amplifier in around 1980.
It was 225WRMS and I used it with four Fane 50WRMS speakers on a mobile disco.
It sounded very good and was very loud when required.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 5th August 2015, 05:53 AM   #569
djk is offline djk
djk's Avatar
"It was 225WRMS "
Bridged?
Max safe voltage on a 2N3055/2955 pair is 30V.
Candidates for the Darwin Award should not read this author.
Old 5th August 2015, 10:16 PM   #570
Bigun's Avatar
You've lost me there Nigel, the Maplin circuit has no relevance in this thread??
How to provide thermal stability for Gabor's amp is the question. I think the issue as always is the VAS, the current through it increases with temperature and this simple Vbe causes increase in OPS current. The VAS emitter degenerate helps but may not be enough and increasing it will reduce OLG. Other option is to make the Vbe multiplier immune to VAS current using solution like my TGM5. Or add some temperature variable element to the input stage like VSSA. What other ideas - there are more options?
My first DIY amplifier 20 years a goHide this!Advertise here!
camelot arthur dac 20 years old inertial Digital Line Level 5 22nd December 2012 09:57 AM
My best sound amplifier of these last 20 years audiodesign Solid State 22 28th August 2011 10:54 PM
new speakers after 20 years sys3 Multi-Way 5 28th May 2006 04:08 AM
Pic: 20 years old wasted on Xmas! Prune Everything Else 5 27th December 2004 10:01 AM
2N3055...supply for 20 years!! Netlist Swap Meet 5 11th June 2003 11:45 PM
