Old 13th November 2008, 05:03 PM   #1
zigo3 is offline zigo3  Italy
Default Please help with double attenuator for biamp
This is my first diy project and my questions are by sure "simples" for you.
I have projected a double attenuator for passive biamp.
I used 2 24 steps 100k attenuators like that Click the image to open in full size.
The idea was connect the imput to the first (A) of the 2 attenuators and connect 2 outputs from that, one to one of the 2 powamps (9wpc) and the other to the second attenuator (B). Then the output of this second attenuator to another powamp (100 wpc). In this way I can equilibrate the power difference of the 2 powamps with the second attenuator B and use the first A to regulate the volume on both.
The problem is that the ouput of the B attenuator is too low even if I regulate it at the maximum: it's so low that it's difficult to hear.
Where I am wrong? Maybe 100k is not correct?
Thanks in advance!
Rob
This is the simple scheme Click the image to open in full size.
Old 13th November 2008, 06:14 PM   #2
you seem to have it the wrong way round.
Input to attenuator A. (= overall volume)
A's output to 100W amplifier + attenuator B.
Attenuator B's output to the 9W amplifier.
/sreten.
Old 13th November 2008, 07:07 PM   #3
/sreten.
You are right...I can't understand why but it is.
Thankyou very much!!!
Now the problem is that I must use B close to the max and if I use the A at max the sound level is medium, far to be high.
5W Zen for biamp tweeter Kanga Pass Labs 16 2nd February 2010 10:58 PM
acoustst 2+1 biamp? Williams Audio Planars & Exotics 8 30th July 2007 05:42 PM
DIY Biamp project docz Full Range 1 25th November 2004 07:50 PM
Biamp: Wich fc ? Higo Multi-Way 18 5th August 2003 12:24 PM
To Biamp or not to Biamp, that is the question??????? Apogee Pass Labs 70 12th July 2002 12:34 AM
Page generated in 0.08215 seconds (69.75% PHP - 30.25% MySQL) with 10 queries
