Old 12th November 2008, 03:16 PM   #1
Default Driving 8 Ohm Speaker
Hello,
I think I am in the right section to post this question. Well here goes. I am trying to build a dynamic Mic amplifier to drive a 8 ohm speaker but the speaker doesn't give any output. I am using a single transistor as a pre-amp.
circuit 1 see attachment
Then I feed the output of the above circuit into a push-pull configuration with more or less unity voltage gain but Supposedly gives current gain.
circuit 2 see attachment
looking with oscilloscope on circuit above (Push_pull) I get about 4vP-P(c2). When I then plug in 8 Ohm speaker at( C2 to GND) the output signal vanishes!!
Anybody know why??
Old 12th November 2008, 04:26 PM   #2
Ted205 is offline Ted205  United Kingdom
Ted205's Avatar
solid state section
Old 12th November 2008, 06:09 PM   #3
Default Driving 8 Ohm speaker help required
Hello,
Anybody know why??
Old 12th November 2008, 06:09 PM   #4
Right you are will copy over to solid state.
Cheers
Old 12th November 2008, 07:04 PM   #5
It appears that your attachments are playing hide and seek, and currently it is hiding. Some may be seeking, but have not found.
Peace,
Dave
Old 12th November 2008, 07:24 PM   #6
lineup is offline lineup  Sweden
lineup's Avatar
Default Re: Driving 8 Ohm speaker help required
When input feed from one (dynamic) microphone for 8 Ohm speaker out ...
1. we need a lot of voltage gain
even for a low level out, we may need amplify x100
2. we need a power supply giving at least at least like 25 mA
3. we need the output stage having high enough input impedance
not to reduce the voltage amplifier gain too much
lineup
Old 12th November 2008, 07:29 PM   #7
danielwritesbac's Avatar
If you wanted chipamp, howabout nte1516 (NEC UPC1212C) Op Amp? That's a "soft clip" chip, and if you get the mic too hott or too close, the output is rounded a bit. That's pretty sweet for stopping some customary problems with microphones. The device will drive an 8 ohm speaker. Options are driving the speaker with BTL config or using the device to drive line level.
Old 12th November 2008, 08:41 PM   #8
Speakerholic
Cal Weldon's Avatar
Two threads have been merged.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 12th November 2008, 09:08 PM   #9
Thanks guys
driving 845's hesener Tubes / Valves 19 23rd May 2008 05:16 PM
76 driving 211? Radames Tubes / Valves 2 17th June 2005 07:54 PM
how's your driving? Daniel-A The Lounge 1 18th May 2004 06:34 PM
Driving SOZ lumanauw Pass Labs 0 17th May 2004 09:33 AM
Best amp choice for driving NASTY speaker loads stokessd Pass Labs 8 25th March 2003 11:32 PM
Page generated in 0.10654 seconds (74.65% PHP - 25.35% MySQL) with 11 queries
