Current Mirror Discussion
Old 26th November 2008, 11:16 AM   #311
homemodder is offline homemodder  Portugal
To get rid of memory distortion in CM try using cascoded mirror, I havent used this in self type circuit but it works and sounds great in a different current feedback design Ive tried.
Old 26th November 2008, 01:54 PM   #312
jam is offline jam  United States
jam's Avatar
homemodder,
Have you tried the additional resistor in series with the cascode as suggested in the memory distortion page?
Jam
Old 26th November 2008, 06:22 PM   #313
Jam do you mean in a current mirror or the resistor in the vas. The resister in the vas is interesting, I havent tried it, but in general I have disliked the sound using cascode in vas and ltp in self type amps. I use very low cob , high speed trannies, and I like the warmer sound without cascode. Maybe this resistor does something to the sound, anyone here that can comment on this ???
Cascoding Jfets works good but now I got hold of some sanyo Jfets and in a headamp I tried them in, Ive gotton rid of the cascode too.
Jam take a look at the buffer thread for my comments on the sound of mirrors with that buffer design of mine.
Old 26th November 2008, 09:31 PM   #314
Bob Cordell is offline Bob Cordell  United States
Originally posted by AKSA
VHF,
Lavardin's technique for reducing 'memory distortion' in the VAS was simply to cascode, removing Early effect in the lower device; but I found years ago that unless you inserted a resistor between the lower and upper device between collector/emitter the clip performance became very ugly.... some mention is made of this by peufeu here where he addresses it as 'the magic resistor'.
Notice the ultimate version cascodes the cascode. I'm not convinced this is the best way to do it, too much cost of rail efficiency, but a simple cascode reduces memory distortion almost ten fold, obviously worth it.
This is a guy who has it all; deep maths insights, clearly a gifted engineer, but one who listens, is not didactic or opinionated, and is not afraid to describe the sound in heavily subjective terms.
I guess this is the engineer's equivalent of dancing.....
Good to see, restores the faith.....
Hugh
Memory distortion is an interesting matter, but bear in mind that the right measurements will often bring it out. Even very low frequency THD can be useful in this regard. Some take THD at 20 Hz for granted and don't even measure it, as it should be "easy" for an amplifier to faithfully reproduce such a slowly changing signal (especially with all of the loop gain often available at those low frequencies). But don't take it for granted, and do be suspicious if it rises above, say, 1 kHz THD. Such "memory distortion" even exists in the feedback resistor as a result of its thermal variations when it is subjected to substantial power.
However, some of these effects are buried in amplifiers that have otherwise high levels of THD.
Another interesting test is to do SMPTE with a low frequency component much lower than the usual 60 Hz.
Another interesting test would be low-frequency CCIF, where 19Hz +20Hz signals are combined, resulting in a 1 Hz signal power envelope.
Bob
Old 26th November 2008, 09:48 PM   #315
AKSA is offline AKSA  Australia
Thanks Bob,
Interesting comments. I guess you would expect memory distortion to decrease at high frequencies, but it should still affect the midrange where human voice lies.
No one talks of dielectric absorption in power amps, presumably at C1, do you have a view on this?
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 26th November 2008, 11:11 PM   #316
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Thanks Bob,
Hugh
On IC's easily out to 50-100kHz.
BTW I'm fairly surprised that no one picked up on the fact that the forward gain path on that "discrete OPA627" I posted is determined to the first order only on pair-wise device match i.e. first order rejection of all thermal distortion.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 27th November 2008, 03:06 AM   #317
Thanks Bob,
Hugh
Depending on the thermal time constants of the elements involved, I suppose thermally-induced memory distortion could have an influence even when high frequencies are involved, since the time variation of the power envelope of the high-frequency signals could play a role. Consider, for example a test tone consisting of 20 kHz and 19,990 Hz, with a power envelope changing at a 10Hz rate.
Not sure about DA by itself, but I do believe in using a high-quality polypropylene capacitor for input coupling.
Bob
Old 26th December 2008, 03:50 AM   #318
robson fulco is offline robson fulco  Brazil
Send a message via MSN to robson fulco
Hello good evening to all friends and have a happy Christmas hohoho
Old 31st December 2008, 05:37 AM   #319
KLe is offline KLe  Australia
Banned
Happy New Year everybody
Old 18th March 2017, 08:26 PM   #320
spookydd is offline spookydd  France
Reviving an old thread gone quiet
But I have a quick question on a current mirror improved with the extra "helper" transistor as in the one posted in post #8. (3 trannies)
In the context of a symmetric topo with the 2 ltps with their current source, if I need the helper transistor's collector not to be referenced to ground, how is it correctly done?
I would think that just linking up the collectors directly between the 2 opposing helpers would not be a good thing. So what would be the right way?
"You're old enough to MOW better!"
Current Mirror DiscussionHide this!Advertise here!
Current mirror for the aleph? 3nity Pass Labs 11 8th August 2013 08:23 AM
High current mirror ? forr Solid State 23 25th June 2009 09:31 AM
Current Mirror: The V-mirror rtarbell Solid State 1 19th November 2008 03:27 PM
no current mirror, current mirror, cascoded current mirror, bjt or jfet VAS? maxpou Solid State 31 17th June 2008 05:31 PM
Current mirror abzug Solid State 7 1st January 2008 08:03 PM
