i have an old mosfet amplifier that (you can see) is a DIY job. it says 600W output but im not sure about that. it has overload protection in the form of relays on the output, and one channel kicks out even at low output levels. and the amp sounds horrible.
so i was wandering what is the best thing i can do with this amp?? should i try and fix it or build a new amp from scratch?? i will obviously use the transformer, and maybe the output transisters??? i know i haven't given many details about the amp, but if there some measurements i should take please let me know. i want to use this amp in a PA/ small disco system, and add a limiter to it so i (or anyone else using it) cant blow the amp or speakers. this will be my first amp project, so i would like to have things as simple as possible |
#2 |
Find out first what you have.. what size transformer is in there, how big are the heatsinks, what power supply capacitors.
Some pictures of it, including the insides might help us. |
#3 |
so the transformer is pretty big (and heavy). its 38-0-38 which pushes out about +- 50v dc. i have no clue how much current i can draw from it but this thing looks pretty industrial!!
transisters are MJ15024 got some pics here, sorry about the quality but i had to compress them to attach: |
#4 |
another pic
#5 |
and another
#6 |
Firs of all 15024 isn't Mos fet.
Pcbs look like PA 300, origin. 600W?, maybe 2x300W. Repair ofcourse!! Regards zeoN_Rider |
#7 | |
is npn 250w. With the hardware you have here, you have many choices. First , with 38-0-38VAC , that gives about 52-0-52 VDC allowing for a 120w amp. looking closely at it shows its age, so the caps should be replaced. The present amp has design considerations (VAS on main HS,etc )but there are many amps here that would work with this "shell". the "power amp under development' (NMOS 200) or in a couple days , my amp "frugal amp" are modern amp designs which would seemlessly just "bolt on" to what you have already.(they use the same L channel for outputs)You could repair it but that is up to you. Dont throw it out because I just had to spend 250$+ to get what you have. (Case , trafo, Heatsink) OS |
#8 |
Well, if you really want to scrap it, you could build the Leach Amp. Do a Google Search. Sound quality is excellent.
#9 |
I'd repair.
it adds a worthwhile skillset.
Just because you can't hear it doesn't mean no one can. |
#10 |
I can confirm it's a PA300 amplifier board. Look at the diagrams here - the layout is identical.
http://www.reber.si/ojacevalniki/PA300/PA300.htm Is the closeup pic of the PCB the faulty channel? I see heavy scorching around several resistors. As you now have the schematic and PCB layout, you could repair it... but i would be wondering why it failed and why those resistors overheated in the first place... it could be a design flaw. Maybe someone here knows the PA300 circuit better? edit: from the look of it the fried resistors are R13, R15, R18 and R19. That would suggest the VI limiting circuit has been activating frequently, ie the amp has been severely abused. I would test the output and driver transistors, replace the scorched resistors, replace T1, T3, T4 and T5. You might also want to check the diodes around that part of the circuit. |
| replace DAC | maxpou | Digital Source | 13 | 21st February 2008 05:51 PM |
| What to do , repair , replace or redesign. | fortuosity | Multi-Way | 0 | 10th May 2006 01:23 AM |
| replace 5y3 | ardan77 | Tubes / Valves | 5 | 15th January 2006 03:41 AM |
| Repair/replace 30-year old B&W DM6 woofer? | jacques54 | Multi-Way | 7 | 20th December 2005 08:31 PM |
| Replace of CDM 4/19 with CDM 4/31? | bezobraznia | Digital Source | 4 | 14th November 2005 03:56 PM |
| Page generated in 0.10844 seconds (78.26% PHP - 21.74% MySQL) with 11 queries |
