Originally posted by Dan2
C5 is electrolytic - i dont know what type of cap it should be.
Electrolytic is fine. Polyester would be better.
the wire link from input (-) to output (-) is replaced with 10 ohm resistor. is this to prevent ground loops???
If I understand you right, yes.
R39 (temperature sensor) is not on the board, and the wire link from T13 to the relay is missing. so the components for the thermal protection are on board, but not being used
( i see now the protection circuit was only used for power-on delay, am i right? but then how did the relay switch on and off after it was powered up?)
D14 (LED) was never connected (also part of thermal protection)
How odd! Omitting the thermal protection isn't too bad as it appears that whoever built it has made alternate arrangements for this - those look like thermal breakers on the top of the heatsink and they probably cut the power in the case of an overheat
R18, R17, R12, R15, R13, R19 were fried and most of them replaced. are these also part of the protection circuit??
No, these are part of the voltage amplifier stage, however if the VI limiter circuit (T4 and T5) have been activating a lot due to abuse, then these parts will have been damaged.
can someone also explain to me what should be connected to "AC clip"?? it was an LED but on the schematic (D12) it looks like an input
"AC" should have a raw AC connection from the transformer secondary. This is used for "Loss of AC" muting. The amp will work without it.
Clip should have an LED connected to ground. This lights when the amp is driven into clipping.
......and one more thing. if i am going to replace the PSU caps, do i need to replace ALL the caps on the amp?? or just the electrolytics?? will this help with the lack of bass??
Yes, just the electrolytics. Replacing the main power supply capacitors will most likely fix the lack of bass issue.
thanks jaycee
after more checking, i found that R11 is supposed to be 15k but is 150 ohms on both amps.
and R12 is 1k5 on the burnt amp rather than 15k, and looks a bit scorched so it wasn't replace after it was burnt, could that be a reason for the faulty relay switching??
termal element?? there are 2 sensors on top of the heatsink that regulate the fan, the one that is in the schematic was never put in
kay well i have bought replacement parts, gonna start replacing tomorrow. the website for the amp says i need 4 10000uF caps for the PSU. i could only get 2 - i hope that will be enough.
ok so now i want to add 2 things to this amp - an audio limiter and an active crossover. both circuits are from Rod Elliott's site.
both circuits need a -15 0 +15 v supply (about) so i was wondering if i can use the supply from the amp which is used for its op-amps ?? or will it not be able to supply the current??
the +- 15v are set up using 3k3 resistors and zener diodes. the resisters look quite big - 5watt i think.
jaycee said:MJ15024/5 are actually a superior substitute for the listed MJ15003/4 transistors, so that is OK
In rails below +/-65vdc... I have found the 15003/4 to be better sounding than the 24/25... but both are workable.
thanks for the info - but i am going to keep the power transistors that are there.
i still want to test this amp at high power for a while to make sure it doesn't cut out, so what is the best way of doing this?? i was thinking of hookin up the speakers and running a low frequency (abt 10hz) for a while. the amp will be working hard and it will be fairly quiet (the speakers i have can't produce really low bass). the only thing i am worried about is burning the speaker's voice coil
- Repair or Replace??
