Hello,
It was raining outside today and nothing good was on the TV.. So I decided to fire up eagle and try to make a very small JLH. I'd appreciate some comments and thoughts on making it even smaller. Mounted off-board: The fuses, output transistors (& resistors), muting relay and the filtering caps. Thanks ! |
#2 |
Hi yoshy, is it the 10w class A circuit?
#3 |
Hi Yoshy
Here, the rain it is a rare phenomenon already. We have to see rain at least 1 month. Weather is cloudy, almost every day, the temp varies between 12 and 20 deg C and year by year we become Africa. Anyway, there is no way to reduce your pcb size, its OK. The distance between the smoothing caps it is big. Try to shorten it. Fill the "T" points on the tracks, with small copper triangles. Avoid the 90 deg corners. They cause parasitic capacitances. Make the supply and 0V tracks thicker. Regs from north Greece Fotios |
#4 | ||
Thanks for the input; about the 0v: would it be better if I used a ground plane instead ? Something like this... Thanks ! |
#5 |
A small, single sided , non-SMT version of the JLH I made some time ago.
Brian. |
#6 | |
That's very nice ! I want to do a SMD version since I have a bunch of 0.1% metal film in 1210 package. I'll will take a look at your layout and see if there's something I can change. Did you build yours ? And if so are you satisfied with the sound ? Thanks, Phil |
#7 | |
Sure would be nice to see the "black & white" etching image seperate from the silkscreen image of the components. I'd like to give it a go. Can you share a little more? I have most of the parts to give this a try. I have also PM'"d you but no response. |
#8 |
"Sure would be nice to see the "black & white" etching image"
Sorry for the delay; took a break to Scotland. I built and bench tested this layout over a year ago without any problems but other designs diverted my interest. Image attached. Best of luck. Brian. |
#9 |
And here's an assembled view.
Brian. |
#10 | |
on a set of these if I put my nose to the grind stone. Very compact layout and if Yoshy uses SMT devices, it could even be smaller! Thank you.
| Getting Smaller | pinkmouse | Chip Amps | 6 | 21st July 2003 02:11 PM |
| Make a Comment on my 15inch sub | mikee12345 | Multi-Way | 50 | 7th April 2003 09:32 AM |
| Page generated in 0.10546 seconds (85.27% PHP - 14.73% MySQL) with 11 queries |
