Hi
I have alot of nice parts under my bed 40 pcs of Rifa PEH169 15000uF/40V 100 pcs IRFP450 from Harris A new toroid 2x21V /1000VA So what can I make of this ?, i have been thinking of a 5CH amp but i cant find any circuts that i can use my parts in.. Iam thankfull for all the help i can get, and sorry for my spelling |
#2 |
I think you should make trip over to passlabs forum, that is if you like class a Amps. Put this same question there.
#3 | |
class a amps are lovely, and i have already built one Aleph amp, but they have one big problem and its the heat , i dont want to use big heatsinks and fan's to keep it cold, so a class a/b or just class b will be good for me |
#4 |
Or secondary voltage to be really useful. Can you add turns to the secondaries, or is it potted in the center?
#5 | |
#6 |
How about stacking four 30-35V? That will get you up to something respectable with those 40V caps. Then you could even do class H and not need much of a heat sink.
#7 |
Class H is new to me .. not sure if i have heard of it
#8 |
No forget class H, stick with A or AB - they sound best.
So you want: - higher voltage /power than from 21v sec - class AB - N-channel FET output (quasicomplemntary) My suggestion is: Make 10 of the "Legend" by Dr. Bora ( use the search function) and drive your 5 channels balanced. It would be an effektive use of most of your nice parts |
#9 |
...allthough with 5x200-240W per channel you might be pushing the toroid at full power. So drive the front L and front R balanced meaning 'only' 7 amplifiers.
...and if you have 8 leftovers caps, then I could sure find some use for them |
| Help whit Ebay/diy zone regulator | valo | Analog Line Level | 6 | 12th June 2009 04:44 AM |
| amp whit k1058/j162 | minnolella | Solid State | 14 | 10th December 2008 08:16 PM |
| 100%working SMPS whit pcb needed | sk_tuner | Power Supplies | 3 | 15th February 2007 11:44 AM |
| Building a guitar pre+ampli, whit effects!!! | TANTINI1977 | Instruments and Amps | 1 | 8th October 2006 11:50 PM |
| Page generated in 0.09065 seconds (85.62% PHP - 14.38% MySQL) with 10 queries |
