please comment my pcb
Old 5th November 2008, 11:16 AM   #1
east electronics is offline east electronics  Greece
east electronics's Avatar
Default please comment my pcb
please comment my pcb Click the image to open in full size.
zobel network is to be located at outpout connector and return to star ground with a separate cable
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 5th November 2008, 11:26 AM   #2
Mooly's Avatar
Hi Sakis,
The only problem I suspect is if you are making two of these to run off one PSU. If you are you need two ground returns to the PSU star from each PCB. Otherwise the two channels will interact.
If not it's OK
Old 5th November 2008, 11:29 AM   #3
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Looks good! Very nicely organized.
One thing:
You have the input ground direct to the power ground?
Old 5th November 2008, 11:29 AM   #4
Mooly's Avatar
Read all of this,
http://www.diyaudio.com/forums/showt...ht=3+stage+lin
Old 5th November 2008, 11:39 AM   #5
Default strangelly yes
One thing:
in fact most of times i did this i had less problems than running ground through 10R resistor
Old 5th November 2008, 11:41 AM   #6
MJL21193's Avatar
Also you could change as I have shown below to avoid that jumper.
Old 5th November 2008, 11:50 AM   #7
Mooly's Avatar
Make sure you read that link. It's very relevant
Old 5th November 2008, 12:37 PM   #8
Default this the config
i have in mind
never tryied that exact config but will see when pcb is ready
Old 5th November 2008, 12:53 PM   #9
Hi Sakis,
I have tried various stereo layouts similar to your last post and I could never get them hum and buzz free.
A monobloc where the Audio Ground is on the PCB works OK, but not when you connect more than one channel.
I don't see your schematic but I wonder if the NFB route sends the inverting input from the correct end of the second (lower leg) resistor?
On the same NFB route, it appears to be tapped off the emitter resistor instead of from the speaker output.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 5th November 2008, 12:55 PM   #10
MJL21193's Avatar
Default Re: this the config
Originally posted by sakis
i have in mind
This is like polluting your drinking water by connecting the toilet to the water well.
Set up an input signal ground that is isolated from the main power ground.
Return the speaker ground to the main power ground, not on the amp board but on the power supply board. Return the Zobel here too.
please comment my pcbHide this!Advertise here!
Please comment my pcb P3a roly3055 Solid State 53 8th June 2012 08:36 PM
Please comment my PCB! Mlaen Solid State 31 11th February 2009 09:35 AM
please comment my pcb east electronics Solid State 15 28th July 2008 08:24 AM
Please comment for my new CFB amp lukio Solid State 11 9th February 2004 03:59 AM
Copyright ©1999-2017 diyAudio
