diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Accidentally wired my amplifier wrong! (http://www.diyaudio.com/forums/solid-state/132465-accidentally-wired-my-amplifier-wrong.html)
Roker 3rd November 2008 01:12 PM
Okay I am going to come right out and say it, I am an idiot!!! I was in a hurry and too excited to use the correct precautions, which would have saved my amp.
I accidentally wired the 12v power to my Rockford Fosgate 5005 backwards, meaning I connected the battery + to the amps - and so on. I was just testing the amp before installing it my car and unfortunately I didn't have a fuse in place. Stupid, stupid, I know. It blew two mosfets and I replaced them already, and what a joy that was. I couldn't get them to solder back to the Mehsa board so I built braces to hold them down using the exsiting screws. Everything looks good so I a hooked it up the right way and I even used a 15 amp fuse. However, I still have a problem with the amp. All it does is blow the fuses when I turn the key and power goes to the REM wire. The fuse doesn't blow until the REM power turns on. It will also blow a 20 amp fuse.
What do I need to do now?
theAnonymous1 3rd November 2008 01:29 PM
Re: Accidentally wired my amplifier wrong!
Have this moved to the car audio forum. ;)
Eva 3rd November 2008 09:04 PM
It seems that the polarity reversal blew more components than just these two MOSFET. Check further.
The MEHSA stuff (intended to avoid you from repairing the amplifier) and the lack of a built-in fuse (intended to help you to blow it) make Rockford amplifiers anything but my favourite ones.
Copyright 1999-2017 diyAudio
