#21 | |
Did someone say decent complementary ? Cost difference between a 4-device vertical MOSFET output stage and an 8-device Lateral Mosfet one is like $20-$25, makes 50 bucks difference for stereo. Which is Hogwash, compared to the total cost of the powersupply and (proper) amp case.
Not so much,.......if it says "ZM" in the corner. |
#22 | |
Hi Jacco, He banged the gate with 9V he said, so he was switching them fully on. Vds close to zero. Jan Didden
/Yes! Its out: Linear Audio Vol 5! I'm not an "accademic", just a plodder who loves a challenge - Ian Hegglun |
#23 |
Thanks for all the comments,
Jacco, cost is a factor for sure. A double die lateral is around £12 GPB. So four of those £50 say all in. The verticals do have an advantage. Tempco issues. The verticals are critical on biasing if you want to run at reasonable quiescent currents. I found 120 ma enough, but the challenge is getting this value from cold and maintaining it through all conditions Rds on. What is the rds of a fully saturated lateral ( single die ) I would have guessed at not much lower than 1 ohm , says he looking at the data sheet. Not specified as such, can be as high as 12 volts at max drain current. Calculator time -- 1.7 ohms. That's why the verticals can bite ! They can become nearly a piece of wire when saturated , not a good choice of words that is it. Gate zobels -- values, connections -- dunno, have to experiment on that one. To be honest I have found them (verticals) brilliant as regards stability etc. Must be doing something wrong
#24 | |
The transconductance/resistance change causes the current to drop fast. About 6A after a couple tenths of a second which fell to about 2A after a few seconds. A while after that the transistor got hot enough for the internal zeners to start clamping the gate at a lower than usual voltage and if the current into the gate terminal exceeded about 10mA they latched up like thyristors dropping drain current to about 0.2A. If the current into the gate terminal was kept low enough to not make the zeners latch up the transistor would respond to decreasing Vds with increasing Ids to keep the same temperature and power dissipation! |
#25 |
Hi megajocke,
That sounds reasonable. 2SK1058 at max Idss, the device can have as a worst case 12 volts Vsd. Which of course reduces efficiency. |
#26 |
This here gathering is DIY and not commercial enterprising, right ?
Hop-shopping across the frontier buys single-die lateral MOSFETs for as low as $3/pc +taxes. Around the corner boutique parlors easily charge $5 for a vertical MOSFET, and without a guarantee that you'll receive all same batch items ! A decent output stage requires at least 4 output devices for thermal efficiency reasons, no matter the type of output device. It doesn't take 3 to 4 times as many Lateral MOSFETs to achieve comparable transconductance numbers as a Verti-M output stage. Read what EUVL had to say about Gm numbers of Lateral/Vertical parts, and about not to read datasheets as the book of psalm. Lateral MOSFETs are not expensive, they cost less than 25 years ago. And 25 years ago, a Vertical MOSFET cost more than a Lateral one on this continent. If someone isn't building crab amps, he'd have to buy more Vertical output devices than the required number he needs if he's going through the regular vendor channels. Tolerances of Vertical parts are larger than those of (Japanese) Laterals. If cost is an issue, then you'd also have to add the paid VA that is lost because of the difference in Gate voltage threshold to the balance.
#27 | ||
You bet there will be gate current required to drive the mosfets at RF. It requires a bit of energy to push and pull the majority carriers into and out of the channel at such speeds. Quote:
![]() The change in transconductance wrt Vgs and temperature is another motivating factor for error correction. If used properly, I agree with Bob, they just can't be beat, but there are certainly some drawbacks one must deal with.
All the trouble I've ever been in started out as fun......
#28 |
Banned
In enhancement types, the control electrode is isolated from the current conducting channel, resulting in practically zero gate current and infinite input impedance. The on-state drive current is zero as well. MOSFETs have a resistive nature, RdsOn of Hitachi devices is 1Ohm @ Ta=25°C, promoting linearity. MOSFETs exhibit a positive temperature coefficient of 0.7%/°C to 1%/°C (- 2.2mV/°C for p-n junction), acting as a negative feedback in parallel operation. RdsOn increases, Gm decreases with increasing temperature. The lateral structure is not efficient. The price of efficiency is always sound quality. |
#29 | |
change in Vgs across the input capacitance requires AC current to drive because Z=1/(2pi*F*C) Also there is Cdg in there too...also not very linear wrt Vds.
#30 |
Banned
CBS240,
well, to my knowledge, no one has been calling for more driving current than I have. |
| cascode output stage what device? | Stefanoo | Pass Labs | 24 | 27th February 2009 03:35 PM |
