#11 | ||
se |
#12 | |
Steve I well understand PSRR, and the fact that the supply pins will be modulated, and according to the level of PS modulation and the degree of opamp PSRR a valid audio output will result.
I believe not to believe in any fixed belief system. |
#13 | ||
Time to go get my eyes checked. se |
#14 |
Steve, it seems that you have not done measurements or else you would be presenting them I expect.
Ditto subjective sonics testing too or else you would be presenting your finding in this area too. Has anybody any subjective data here ?. Eric.
#15 | ||
se |
#16 |
Banned
eric,
Even on cd-players, preamps, etc. sometimes I see resistors on the power supply lines before op-amps. They are there to try to isolate the component from other components sharing the same PSU, and to reduce the current entering the op-amp. I change their value only if the supply voltage is low on the op-amp pins (it happens very often, and you can get more 2 or 3 volts). As for subjecctive results... Well, everytime I get the voltage as I like, I get better results. The sound is faster, cleaner and more dynamic. I don't see a necessity to limit too much the current of a 7815 or similar. They won't hurt an op-amp. |
#17 | |
Hi, Thanks that is the sort of reply that I was seeking. Can you give values for particular opamps ?. Thanks, Eric.
#18 |
Banned
Eric,
In general, OPAs (2604, 2132, 627/337, 228/2228) like to be driven above +/- 10volts (this applies to most other op-amps too). Below that you notice immediately they don't play as they should. Maby some people don't bother with this, but it's really important. An OPA2604 works until +/- 24v, but I never tried to go over +/- 18 volts. I say that generally for any op-amp the optimum is between +/- 15v (the standard normally) and +/- 18v (the limit for the majority of them).
| decoupling caps for dip8 opamp - are they just there for a regulated supply? | Archwn | Chip Amps | 7 | 20th December 2006 04:52 PM |
| Opamp decoupling | Khron | Chip Amps | 1 | 12th September 2006 04:36 PM |
| Opamp decoupling schemes [& Better grounding] | kaushama | Chip Amps | 5 | 8th December 2005 09:57 AM |
| opamp decoupling, and biasing | audiokid25 | Parts | 1 | 25th April 2005 08:40 PM |
