quick solid state amp question quick solid state amp question - Page 6 - diyAudio
Old 19th November 2008, 02:23 AM   #51
cbdb is offline cbdb  Canada
And some of those old tubes might like to stay on all the time?
Old 19th November 2008, 02:35 AM   #52
anatech is offline anatech  Canada
anatech's Avatar
Hi cbdb,
Actually, no. Only a few items were designed to run all the time. PA systems (that's why they are class B), computers (those tubes are designed to be kept in reverse bias) and some military or industrial things (like radars, telephone amplifiers - repeaters, etc..). Anything that was left on all the time had a maintenance schedule, even factory PA systems and early Terryphone systems.
If you leave tubes on with full heaters and no B+, you can "poison" the cathodes. The emission drops and noise increases. You are way further ahead to simply turn the item off (entertainment sound equipment).
These days, solid state equipment has lower maintenance if it has to be left on at all times, but there is still a maintenance program to look after that stuff. That is if the factory or installation actually expects their equipment to work when needed.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 19th November 2008, 08:50 AM   #53
Ragnwald is offline Ragnwald  Sweden
Ragnwald's Avatar
Originally posted by anatech
Some amplifiers have poor control over the bias current. These take a long time to settle into the normal operating range. This is a defect in design actually. It is perfectly possible to design amplifiers that have settled in within 1/2 hour. Heck, that is the time needed for very accurate measuring instruments to stabilize. If an amp hasn't stabilized within half an hour, it will never settle in.
-Chris [/B]
Ok, if its not temperature dependent, what (more specific) exactly happens this 1/2 hour before we can lean back and listen to our favorite records under full control?
quick solid state amp questionHide this!Advertise here!
Solid state Class-A question neazoi Solid State 7 29th March 2009 10:43 PM
question ad146 solid state amp arhi45 Solid State 0 29th May 2008 06:42 PM
The Solid State Wiki - Your solid state reference guide Jason Solid State 0 25th June 2002 05:26 PM
Copyright ©1999-2017 diyAudio
