Amplifier DC Offset - How Much is OK?
Old 25th October 2008, 09:45 PM   #1
ronzeman is offline ronzeman  United States
ronzeman's Avatar
Default Amplifier DC Offset - How Much is OK?
To tweak or not to tweak...That is my question. I am wondering how much DC offset (at the output terminals of my amplifier) is "acceptable", normal, or too much?
My amp in question is a Hafler 9180
After idling for about an hour...no load... no input; nothing connected; I checked the outputs for DC offset: R= 25.1mv L= 50.9 mv
If I'm biamping w/ this amp is the DC too much to stick directly on to a (midrange) driver ?
Old 25th October 2008, 11:16 PM   #2
lineup is offline lineup  Sweden
lineup's Avatar
i think 50 mV and less is alright
it is not easy to get lower, as there will be a drift in most power amplifiers
as you play music and temperatures changes in amplifier components
mainly semiconductors, transistors and diodes are effected
at what level should we begin to be concerned?
I have noticed some say that 100 mV is beginning to be uncomfortable
Should be noted here, that there were in past some amplifiers
that had loudspeaker as the bias component,
to feed the amplifier a small current for start up.
radioam232 Simple Class A.
This amplifier defintely will have some dc-offset!
Now, he is only using very small Class A current. And it works.
As can be seen from his videos.
He has got 203 youtube videos - most related to electronics
small audio amplifier class A
http://www.youtube.com/watch?v=waK38uzRgBw
small audio amplifier class A tested
http://www.youtube.com/watch?v=TfpOIH7k7lQ
lineup
Old 26th October 2008, 12:39 AM   #3
eyoung is offline eyoung  United States
eyoung's Avatar
Ditto... 50mv and less is good . on this amp to get any less would require some differential transistor matching and checking for any leaky caps...
Elwood
"Lead me not into temptation...I can find it myself."
Old 26th October 2008, 12:53 AM   #4
ronzeman's Avatar
Default 50mV or Less ?
That's somewhat reassuring BUT...I'm planning on using an active crossover (Marchand) so the speakers will not have a passive XO (with its caps) in line between amp and speakers. I worry about sticking my speakers right into the amp outputs IF the offset is "excessive". Hense my question...what is excessive ?
Old 26th October 2008, 01:02 AM   #5
djoffe is offline djoffe  United States
Default too much offset?
I don't think this is a problem. If you calculate the power, V^2/R,
assuming R is 4 Ohms, you get a power of 0.625 milliWatts. This shouldn't be an issue.
One might argue that the slight offset from zero of the mechanical suspension would cause a bit more 2nd harmonic distortion. Still,
we're talking about 50 mV compared to 14 V peak, if you assume a
25 watt driver rating...that is a displacement of 0.36% of the maximum. Surely purely mechanical issues could cause this much displacement.
In summary...I don't think 50 mV will cause any problems.
Old 26th October 2008, 11:50 AM   #6
lineup's Avatar
From the safety there is no problem
even 1 Volt offset or even 4 V for one larger 8 Ohm speaker
Power = UxU / R
Power = Volt x Volt / Ohm
4x4 /8 = 2 Watt .. which corresponds to a 4 Watt rated Woofer. (ACwatt = DCwatt x 2)
'Max output' level may decrease a bit, as at one swing of the cone
it will sooner reach the limit of travel.
But how many play their speakers to the limit Only a few fools.
How much an 1.0 Volt offset, for example, will increase distortion
is something that needs to be investigated.
Personally, I think this is much less than what we might imagine.
And very much different from Woofer to Woofer.
However, keeping the DC-offset not to high is a good thing.
Where the limit will be, is most a question of your personality,
how afraid you are of things, Ghosts.
Your self-confidence
lineup
Old 26th October 2008, 12:11 PM   #7
Patrik Floding is offline Patrik Floding  United Kingdom
Default Re: 50mV or Less ?
50mV is not much for a woofer, even though you may be able to see a slight displacement.
However, 50mV is not so little for a treble unit. So it would probably be safest to use a high quality coupling capacitor for the treble unit.
Just my .02
Old 26th October 2008, 06:34 PM   #8
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default This depends how much neurotic you are
If you measure 1 milivolts when cold... then you may start to have concerns..... when hot it may jump to higher values!... then you gonna loose your peace because of that.
Off set does not sound.... big or lower, it is just a perfectionist care...if possible to remove..why not to remove? make it zero or the minimum possible...will make academic folks smile... as they have enormous calculations to avoid that and the dam off set is always there..ahahahahah!.... match transistors...will make your off set zeroed.
Many amplifiers (thousands of them) ask you to adjust to less than 25 milivolts...and this is not to loose from others that are asking the same.... because you may think they are second class amplifier because not bothering about off set...more politically accepted thing than real technical worries.
Let's say you will have a huge off set (referenced to the standards) of 150 milivolts... this will move the speaker upwards or backwards a tenth of milimeter into a high power speaker and more to a low powered speaker..... but the speaker, by itself, is already non perfectly centered..means..it can move more milimeters into one direction when compared to the other direction of movement...the opposite related the first one.....so.... you will not bother the speaker...he is already out from all kind of precision.
If you are neurotic..then the first movement must be upwards and them the second must be backwards... and be carefull!...not the opposite, because electrons will be confused!..will enter a hard strike, they will not work anymore!
When the amplifier goes on (switched on...power on!)...if a good amplifier..will not have "power on" thump...but big offset will make a "power on" "tic"...not a "tac!" and not a "thump!".... so... having off set, you gonna have "tic"... and will need delayed insertion circuits and relays..because of the "tic" sound.
Waste of power.... well folks..... 150 milivolts... may be 2 miliwatts... i do not think you are wasting too much ... each Led you may have into the frontal panel will waste 10 miliamperes.
Some people thinks because this error... that can be positive or negative, will result in different size into the waveform... negative!... will not produce that...no misterious distortions will be produced too..also you will not attract the Devil to your home...your cake will not burn into the fire...your steak will not have too much salt...your wife will not move to another town with your gardener...your automobile will not spend more gasoline and your dog will not spell the yellow liquid into your shoes.
But if you are neurotic...well..... better to remove the off set.... maybe the Global heating will be caused by you...please!... adjust that thing please!.... it is hot here man!.... hurry up!
But if you are reasonable stable inside your mind... in other words, not too much neurotic, paranoid, schizophrenic, hysterical, psychotic... then you can send the off set to hell, then you may go listening and enjoying music, you may kick your wife's dog because the idiot barks too much and before that will toast your barbecue without be thinking if what the dog means while barking, .... well.... enjoying your good life without such a kind of nonsense worries other folks, less happy than you are, can have.
regards,
Carlos
Restriction removed ; ttps://www.youtube.com/watch?v=3ioyOjAzDt0; https://www.youtube.com/watch?v=uFcnddpe3MU
Old 26th October 2008, 06:51 PM   #9
traderbam is offline traderbam  Europe
traderbam's Avatar
Carlos is pragmatic as ever.
My opinion is that it is "normal" to expect a commercial amp to have 50mV or less offset. Well-designed high feedback amps or amps using servos should get below 5mV. In terms of typical loudspeakers being damaged, 500mV is safe enough.
Old 26th October 2008, 08:13 PM   #10
darkfenriz is offline darkfenriz  Poland
darkfenriz's Avatar
How about tranformer buzzing mechanically?
There seems to be a direct dependancy on offset voltage...
Amplifier DC Offset - How Much is OK?Hide this!Advertise here!
DC offset in Mission 777 amplifier tkwou Solid State 33 28th March 2017 07:00 PM
create a DC offset value for non-inverting amplifier finding_apple Parts 4 4th June 2008 09:01 AM
dc offset for nakamichi amplifier 1 reddish75 Digital Source 1 7th January 2007 06:47 AM
Zero DC Offset nitin Solid State 3 6th January 2005 05:28 PM
DC offset need help again :-( djdamix Solid State 13 26th October 2004 08:38 AM
