Old 24th October 2008, 08:06 PM   #1
Stee is offline Stee  Italy
Stee's Avatar
Default Powered OPA amplifier
http://www.eserviceinfo.com/download...%20usa370.html
all stages have a gain... (no current stage)
so this can have a brilliant sound
visit my best audio idea http://www.esafono.it/DACTONE.htm
Old 24th October 2008, 08:22 PM   #2
Stee's Avatar
Default and traditional variation
without output capacitors
Old 25th October 2008, 03:39 AM   #3
djk is offline djk
djk's Avatar
Thos are not output capacitors, they are the power supply capacitors.
In many of the QSC designs the output/capacitor node is also hooked to the center tap of the power transformer.
Candidates for the Darwin Award should not read this author.
Old 25th October 2008, 06:37 AM   #4
ostripper's Avatar
That is a QSC USA400 PA amp, simple 100w PA amp.
It would make a good sub amp as it is not as refined as
a leach or Self amp. Good for simple first project.
Old 25th October 2008, 07:24 AM   #5
Mooly's Avatar
The "ripple null pot" is a real giveaway as to it's intended use.
Old 25th October 2008, 08:05 AM   #6
Stee's Avatar
Default correction
http://www.esafono.it/usa3701.pdf
the original source design have a particular Patent
for output capacitors
See version 3
Old 25th October 2008, 10:50 AM   #7
sakis is offline sakis  Greece
sakis's Avatar
Default perfect designs
they have everything .....
-solid rock
- class AB+B topology
-wonderfull sziklai ( output configuration provides also some gain )
-average quality
-extremelly simple to make
-low cost
-soft cliping
-much more effective than class AB +- 15% more
-less heatsink requierd
-with good constuction you may drive extremelly low loads
and from latest expirience they can also drive strange loads without problems but quality remains average at all application
lets face it a simple device may produce all the above but with average quality ....
if i ever meet sziklai i will buy him a case of beers
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 25th October 2008, 02:20 PM   #8
lineup is offline lineup  Sweden
lineup's Avatar
Great Amplifiers, Stee
Keep up the good work.
lineup
Old 26th October 2008, 12:48 PM   #9
Stee's Avatar
Default Thanks a lot
see the ideal application on phono balanced chain
Old 2nd November 2008, 08:41 AM   #10
Stee's Avatar
Default Powered OPA Class A
http://www.esafono.it/allgainstages4.jpg
this version four have little power
new amplifier for 1970s powered advents thetube0a3 Chip Amps 18 22nd February 2012 04:02 AM
USB-Powered Headphone Amplifier joneeboi Headphone Systems 0 25th May 2009 04:07 AM
Firewire powered amplifier? ThSpeakerDude88 Chip Amps 2 9th August 2007 09:16 PM
DC powered guitar/vocal amplifier Lawrence Chip Amps 3 14th July 2003 04:22 PM
Page generated in 0.10539 seconds (78.20% PHP - 21.80% MySQL) with 11 queries
